| [FINALIST] - CraftsmanQuad's CraftsmanQuad Mark II [2019 buildoff entry] | |
+18Murraymountain prancstaman TheRainbowBoxer diddie mr.modified Stretch44875 redzz02 Double W Cross Ranch muddstir AllisKidD21 Hillbilly Offroading Crazy_Carl mowerjunkie03 MatthewD TheBeal SebastianAlbrecht MightyRaze CraftsmanQuad19 22 posters |
redzz02 Site VIP
1st Place Build-Off 2015
1st Place Build-Off 2017
1st Place Build-Off 2018
Age : 23 Join date : 2016-04-12 Points : 5749 Posts : 2620 Location : Indiana
redzz02 Site VIP
Age : 29 Join date : 2010-05-12 Points : 6169 Posts : 899 Location : PA pittsburgh and pymatuning
Age : 25 Join date : 2016-07-10 Points : 8380 Posts : 5190 Location : Ontario Canada
| Subject: Re: [FINALIST] - CraftsmanQuad's CraftsmanQuad Mark II [2019 buildoff entry] April 1st 2019, 12:49 pm | |
| - redzz02 wrote:
It's all good haha I hit the throttle instead of the clutch, that was my fault Uh oh, that sounds like a recipe for disaster! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
redzz02 Site VIP
mowerjunkie03 Member
Age : 20 Join date : 2018-10-29 Points : 2389 Posts : 342 Location : Burnt Ranch, California
| Subject: Re: [FINALIST] - CraftsmanQuad's CraftsmanQuad Mark II [2019 buildoff entry] April 6th 2019, 12:16 am | |
| Looks great man. For the suspension I think it is going tl work out very well but make sure it doesn't sent your front end up to high. Most A-arm swaps I have seen leave the front at least 3 or 4in higher. Lovely gussets kn the trans mounts! As for the frknt trans mounts you have to be careful how you reinforce those because there made to bend alittle when you tighten the bolts down. What I did is just weld them in and leave the bolts like you with the bach plate. As far as I know Stretch also just welded them it. If I remember correctly you said you have ridden one of the mowron rallys. Did it have the deck height slap shifter? Did it feel pretty easy to use or was it awkward? I personally want to cknvert mine to side shift I feel like that is the easiest to use. Just my 2 cents looks awesome man!! | |
| Subject: Re: [FINALIST] - CraftsmanQuad's CraftsmanQuad Mark II [2019 buildoff entry] April 6th 2019, 12:42 am | |
| Very neat idea with the T-post brackets there! As MJ mentioned it's probably a good idea to do some experimenting with chassis weight and spring rate before you get the coilovers and mounts in place. It would suck to have the sprung mass too light to provide enough compression and screw up the ride height, especially for an independent setup like this cause the camber might be outta whack as well.
Either way I'm sure you'll make it work! Do the control arms have some caster angle made into them or are you gonna have to tilt the assembly back a bit to add it yourself? It looks like they have none but it's a bit hard to tell. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: [FINALIST] - CraftsmanQuad's CraftsmanQuad Mark II [2019 buildoff entry] April 6th 2019, 1:38 am | |
| MJ- yes I rode the ghost rider and it had the slap shifter. I liked it a lot. I was gonna just use angle iron but I came across this T stock from a garage door opener and I know I can lay some nice beads when I don’t have to jam my gun into a corner
AK- you bring up some good points. These shocks have a sleeve with notches cut into it to add preload to the springs. I have them set to the lowest setting now as a baseline. I know that the whole tractor with the big vanny and all my angle iron will be much heavier than the 110cc atv they came off of. I’m worried about the nose sitting too low so that’s why I’m starting with them at their lowest preload. As for caster, I’ll have to add a few degrees and kinda eyeball it. You have any suggestions as to how much I should add? | |
muddstir Member
Join date : 2012-01-22 Points : 4830 Posts : 318 Location : Western,PA
| Subject: Re: [FINALIST] - CraftsmanQuad's CraftsmanQuad Mark II [2019 buildoff entry] April 6th 2019, 8:46 am | |
| 5 to 10 degrees is what I try to set my caster at, prefer more towards 10. Another thing to look at in a front a-arm swap is camber in the spindle. Some atv' s have it built into to the spindles and others use different lenghts of a-arms (between the upper and lower). Then some even use different lenghts of a-arm mounting tabs (between upper and lower a-arms ). | |
| Subject: Re: [FINALIST] - CraftsmanQuad's CraftsmanQuad Mark II [2019 buildoff entry] April 6th 2019, 8:58 am | |
| Yeah, I agree with muddstir that 10° is probably good.
Since you are using those straight brackets I would say a real simple way to do the caster angles is once you figure out where the assemblies are gonna go on either side, use a square and draw a vertical line on the side of the frame that lines up with where the rear brackets will be. Then simple use a protactor to make a line 10° off the first line. Then align the rear T-post brackets with the new line, clamp 'em, and weld 'em in!
If that makes any sense....LOL. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
Age : 22 Join date : 2018-02-27 Points : 3639 Posts : 1299
Stretch44875 Administrator
Age : 49 Join date : 2012-04-05 Points : 5494 Posts : 959 Location : Mansfield, Ohio
| Subject: Re: [FINALIST] - CraftsmanQuad's CraftsmanQuad Mark II [2019 buildoff entry] April 12th 2019, 4:54 pm | |
| - Stretch44875 wrote:
- Looking good.
Slap shifter he was using is probably our best one, we used deck button To lock it in neutral. Thanks stretch, from you that means a lot. I really liked the way the ghost felt and plan to incorporate the locking mechanism on the shifter so it stays in neutral | |
Age : 34 Join date : 2013-11-02 Points : 6956 Posts : 2906 Location : New Jersey USA
| Subject: Re: [FINALIST] - CraftsmanQuad's CraftsmanQuad Mark II [2019 buildoff entry] April 13th 2019, 12:28 am | |
| - mr.modified wrote:
- I haven't been around here quite as much recently, but ohhhhhhh yeah man, joining the front suspension club! Looking good!
Haha yeah man, I’ve never had any issues riding, but man did haspin beat the tar outta me. Anything I can do to make this pig ride better imma do it. Next steps are weld front end together, weld the dash on, order the new final drive, clean out all the old grease, and lock the differential. Then the transaxle is ready to go back in and I can start on the belts and pulleys system. After that will be steering, and then wiring (one of my machines will finally have electric start lol I’ll be spoiled), and maybe throw a few coats of black on the frame for rust prevention. This will also be my first tractor with lights so...there’s that | |
diddie Member
Age : 56 Join date : 2016-10-02 Points : 3223 Posts : 411 Location : Indiana
| Subject: Re: [FINALIST] - CraftsmanQuad's CraftsmanQuad Mark II [2019 buildoff entry] April 15th 2019, 10:45 pm | |
| Nice job on those welds! Nice to see it all hanging on the frame, pretty cool. The geometery however looks a tiny bit off to me, in relation to the pivots on the king pin vs the A-arms mounts: It might only be the picture making it look worse than it is, but it looks as though the pivot points are closer together on the mounts. I would think that would cause the wheels to camber in a bit throughout up travel because the arms are, in theory, not traveling the same radius. Might not be so good at high speeds.. Like I said though it might just be the angle of the picture screwin' with me, haha. Sorry for any confusion. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: [FINALIST] - CraftsmanQuad's CraftsmanQuad Mark II [2019 buildoff entry] April 16th 2019, 9:34 am | |
| Ah okay. Well I guess as long as it's the same as it was on the original machine, it'll probably be fine.
Looking forward to seeing more progress! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
TheRainbowBoxer Moderator
Age : 49 Join date : 2012-04-23 Points : 5492 Posts : 1089 Location : Galion, OH
| Subject: Re: [FINALIST] - CraftsmanQuad's CraftsmanQuad Mark II [2019 buildoff entry] April 16th 2019, 9:48 am | |
| - CraftsmanQuad19 wrote:
- Currently welding the front suspension up. I’ll be honest, I just eyeballed where I think it should go haha
Eyeballing is A-OK. This thing's going to Haspin, not to outer space... Although I'm not sure which environment would be harder on the equipment. | |
