| 1997 Murray widebody trail mower | |
+17CornShuck4CE countryboy1995 Moose the54 TheRainbowBoxer Lawren Wimberly LAWN MOWER MUDDER TheBeal T-Dub13 willis923 richie thomas redlinemotorsportts Thunderdivine Ariens YT11 crafsmankiller mr.modified 1997 Murray 21 posters |
T-Dub13 Established Member
1997 Murray Veteran Member
Age : 25 Join date : 2013-11-13 Points : 5260 Posts : 1311 Location : NW USA
| Subject: 1997 Murray widebody trail mower January 2nd 2014, 11:49 am | |
| yours is a pan frame (solid stamped steel) widebodys have a c-chanel frame that the body, dash, and other suff bolts to. most people say that they have the best frame but the worst cluch (one pulley pushing halfheartedly on the tight side of the belt. | |
Age : 54 Join date : 2013-12-06 Points : 4386 Posts : 540 Location : Central MA
| Subject: 1997 Murray widebody trail mower January 14th 2014, 1:11 pm | |
| I'm thinking about replacing the kawisaki with a 14.5 briggs single. what do you guys think? It came out of a murray, cause the muffler looked like another murray muffler i have. | |
TheRainbowBoxer Moderator
Age : 49 Join date : 2012-04-23 Points : 5515 Posts : 1091 Location : Galion, OH
| Subject: 1997 Murray widebody trail mower January 17th 2014, 11:28 am | |
| hopefully I can fix the dash this afternoon. got to get big washers, can't weld cause my uncle stole my welder | |
| Subject: 1997 Murray widebody trail mower January 20th 2014, 1:13 pm | |
| got it fixed! there was only one bolt holding it on, and my battery fell in the belt and got chewed up got a new throttle and a different carb so now it goes a lot faster hopefully I can get a new engine pulley soon, the stock one is terrible! | |
the54 Member
Age : 30 Join date : 2014-01-12 Points : 3840 Posts : 51 Location : Ontario Canada
| Subject: Re: 1997 Murray widebody trail mower January 20th 2014, 6:49 pm | |
| - richie thomas wrote:
- 1997 Murray wrote:
- it worked! it got up to 300 degees f going up hills and smashing brush when I was making trails and mudding. once it warmed up it stayed at 300.
dont know if that is a safe temp for it to run at tho lol......most cars stay under that Most cars run around 90 C. Also they take the reading from the block not the head. The head is gonna make a lot more heat then anywhere else other then the exhaust especially on an air cooled engine. | |
| Subject: Re: 1997 Murray widebody trail mower February 4th 2014, 1:08 pm | |
dont know if that is a safe temp for it to run at tho lol......most cars stay under that Most cars run around 90 C. Also they take the reading from the block not the head. The head is gonna make a lot more heat then anywhere else other then the exhaust especially on an air cooled engine. Looks like there's part of the shroud missing from the pic posted earlier. If so, putting it back on will help it run a little cooler and prevent hot spots on the head. But yeah, the head is going to run hot. | |
| Subject: 1997 Murray widebody trail mower February 5th 2014, 10:56 am | |
| got rid of the john deere electrical system and the Kawisaki engine, and got the briggs on! now I have to make a wiring sistem and decide whether I want to do a direct throttle or leave the govenor on it. also got a good picture of my dash | |
Moose Established Member
Age : 35 Join date : 2014-01-12 Points : 4765 Posts : 919 Location : Defiance, Ohio
| Subject: 1997 Murray widebody trail mower March 3rd 2014, 3:06 pm | |
| got to work on this a little before school, was spinning it over by hand to distribute the oil before i started it, and it started! I guess my key was hooked up wrong.. does anyone have a diagram to use when you want to keep the key switch? | |
willis923 Veteran Member
Age : 27 Join date : 2013-04-10 Points : 5575 Posts : 1408 Location : Galway NY
Age : 27 Join date : 2012-10-31 Points : 4978 Posts : 745 Location : The Wyo-Braska Panhandle
| Subject: 1997 Murray widebody trail mower March 4th 2014, 10:26 am | |
| yeah, this was the engine that I was going to give to you, and the 700 woold be nice to have right now, but maybe I can find one localy. | |
| Subject: 1997 Murray widebody trail mower March 7th 2014, 12:46 pm | |
| well, bought a 6" cast iron pulley for $44 yesterday, along with a starter silinoid and some other stuff for my mowers. started up the montgomery wards and drove it for about 10 min before the engine sized. good news is, the 17 hp teccy fits with 1/2" to spare! also got the pulley on the murray and took it for a spin. it goes about 22 mph, which is not quite fast enough... good thing that I have a 3" to go in place of the 4" that is on the tranny now. Oh yes, I got 2 quarts of 80w-90 for the trannys, so hopefully that will help the tranny stay together... | |
countryboy1995 Member
Age : 29 Join date : 2013-09-25 Points : 3936 Posts : 45 Location : Marion,NC
| Subject: Re: 1997 Murray widebody trail mower March 16th 2014, 5:11 pm | |
| this is a nice build I think murrays are the best for off road builds ive got a murray im gonna start building on when I have the time | |
CornShuck4CE Member
Age : 35 Join date : 2014-04-07 Points : 4050 Posts : 337 Location : Woodville Al
| Subject: Re: 1997 Murray widebody trail mower April 8th 2014, 10:10 pm | |
| 44 bucks is a lil steep check tracter supply out look in tracter section where the chain is and there are collers and pulleys you weld together for about 22 bucks from 3 inch up to anout 14 inches | |
