| Hillbilly Offroading's "Mud Stompin Wards" Montgomery Ward Mud Mower [2020 Build-Off Entry] [Finalist] [Winner] | |
+8CraftsmanQuad19 Creepycrawler Murraymountain RichieRichOverdrive mr.modified AllisKidD21 MightyRaze Hillbilly Offroading 12 posters |
2019 Build-Off Entrant
1st Place Build-Off 2020
Age : 22 Join date : 2018-11-09 Points : 2645 Posts : 582 Location : Reeses Mill, WV
Age : 49 Join date : 2016-09-06 Points : 15056 Posts : 10634 Location : Oklahoma
Northwest_Ohio_Mud_Mowers Member
Age : 17 Join date : 2020-12-07 Points : 1298 Posts : 47 Location : Northwest Ohio
| Subject: Re: Hillbilly Offroading's "Mud Stompin Wards" Montgomery Ward Mud Mower [2020 Build-Off Entry] [Finalist] [Winner] January 25th 2021, 3:01 pm | |
| It's already time for a make over on the '72 Montgomery Ward. After 25 days since I got built and running for the 2020 Atltf Build-Off I'm not fully pleased with it. Theres some things with appearance and functional things that need to be upgraded, fixed or redesign. As it sits its been ready to go riding but I was having some clutch issues. There solved but I lost a good bit of wheel speed its in for a redesign. Heres the plans. The list keeps going. Some happening now that won't take any . Some later this year and some with be later down the road. Let me know your thoughts and what you may or may not like. I'm open for ideas. Playlist of all the videos leading to this point https://www.youtube.com/playlist?list=PL38WkMNv4-mOUjQIc3sTCfxzWELW97Vp_#1 6" Sear 10/8 GT Seat Spring Upgraded. #2 Remove the 7.5"x14" Rear Rack I Built. #3 Install 37"x19" ATV Rack. Will be 8" higher then the existing one so its above the fenders and tires. #4 Drill multiple level holes in the fenders to clear the 27" vamps better & make adjustable to the tire hight that id be running when ever 25"-30". #5 Trim 1.5" off back side of foot boards I built to clear 30s in the future. #6 Cover foot boards in bed liner and spary paint blue over them for scratch resistance. #7 Lengthen the Shifter & Parking Brake Arms. #8 Custom Piston Shifter. #9 Kick the Rear Stance out little wider - 43" now to 45" or 46". When I'm done with it the seat gonna be about 6" higher then what it is in this picture. #10 Bead Locks front and rear. Believe i have materials. #11 Lengthen Sheering Shaft for steer wheel it sit higher #12 Clutch arm piviot point will be moved back to be able to run a 5", 5.5", or hopefully a 6". Running a 4" now. #13 Transaxle has been upgraded from a 2.5 to a 3" to be able to run a ⅝ belt. If I can run something larger on the gear box this Pulley will go up in size for slippage issues. Right now with the 3" it will actually pop wheelies before it wouldn't. Yes it does way because in the mud hole. Lol! #14 Cut hood in half where the grill meets the hood. Solid mount the grill & weld 2 door hinges flip up and have a kick to hold hood up. #15 Lock Peerless 2300 #16 Id like to find a sheet of polished aluminum for dash. Really cleans a build up. #17 Steering Stops and pivot lock. #18 Searching for a Vanguard or Command but I probably won't find one so I'll be dropping in a 16hp Cast Iron Briggs with a few mods done to it. #19 Exhaust system. #20 Slide the axle forward 4"-6" to be able to clear my 22s all the way and larger tires later down the road. Right now at full articulation I can not turn the tires much with out hitting foot boards. Stretching will require me to cut the frame in front of the engine block. On my parts tractor I will cut the frame behind the engine block and it should work. The pivot point for the axle it actually part of the cast iron oil pan so I'm gonna need the oil pan and frame rails from the other tractor to stretch mine. That being said the axle will be at the very front of tractor but not passed the hood. Ill have about 6"-8" of frame past the front of the tractor to actually mount the winch to the frame instead of a bolt on winch bumper like I have now. Its gonna be interesting to see how this all turns out. This will be on hold for awhile so it doesn't screw the year up with riding with a group of guys NW of me in Ohio. | |
