| MTD off-road romper build. | |
+66MightyRaze ranch king pro 08 Axelsol89 CraftsmanQuad19 mowerheadder STUNTMAN JON Rockinator prancstaman MatthewD WilliesBuilds 98svtcobra MurrayMayhem jack9102 802 Customs untrusty huskee redlinemotorsportts Carshowkid rarbaugh07 mr.modified ZSmachines Deluxe66 Jerbear0612 Moose kawasaki220 Angchor B440 jamcco Craftsman1998 breadtrk camomanusa mrkadage MoWheeler Lawren Wimberly mzeng100 TheBeal T-Dub13 richie thomas GenevaCustoms muddstir 1997 Murray TroyBilt Pony Stretch44875 willis923 cumminsbayou crazykid1994 Creepycrawler k2500life xxXMowerdudeXxx genegillis5 TheRainbowBoxer Jamus LAWN MOWER MUDDER MowBandit 1993-Sierra-Z71 craftsmancole Doc Sprocket motorizedeverything flamudmower Murray modder Chopperhed Thunderdivine Ddwannabe mudmonkey06 Ariens YT11 Doug truckin42 70 posters |
Carshowkid Member
| Subject: Re: MTD off-road romper build. March 4th 2015, 10:25 pm | |
| Red this tractor had come so far and all... But those rear Kendra's I think... Look insanely awesome!!! | |
| Subject: Re: MTD off-road romper build. March 4th 2015, 10:37 pm | |
| - Carshowkid wrote:
- Red this tractor had come so far and all... But those rear Kendra's I think... Look insanely awesome!!!
Hopefully it looks better when i groove the knobbys. youll see. I have some more junk ill be able to get done to this, its going to be above freezing for majority of next week! Shop time | |
Carshowkid Member
Age : 24 Join date : 2014-07-22 Points : 3962 Posts : 347 Location : Downers Grove Illinois
| Subject: Re: MTD off-road romper build. March 4th 2015, 10:49 pm | |
Hopefully it looks better when i groove the knobbys. youll see. I have some more junk ill be able to get done to this, its going to be above freezing for majority of next week! Shop time lucky!!! You have a shop... I have a drive way whenever it's above 10F ... Until April when we build a garage. But why are you cutting perfectly good knobbies? | |
Carshowkid Member
| Subject: Re: MTD off-road romper build. March 8th 2015, 10:06 pm | |
| Just go out to St. clair pa and get all the free tires you want. Sure you might have to pick through to find good ones. I'm gonna stop out that way monday and get my reading anthracite access permit. I'm gonna check if those 12" atv tires are still where I left them. Need a good spare for the baja sears. I think there was two there, but they weren't exact matching tread. Might be a bit dry rotted by now, it was about a year ago when I saw them. | |
TheBeal Veteran Member
Age : 29 Join date : 2013-06-06 Points : 5504 Posts : 1398 Location : Central PA
willis923 Veteran Member
Age : 27 Join date : 2013-04-10 Points : 5552 Posts : 1408 Location : Galway NY
| Subject: Re: MTD off-road romper build. March 9th 2015, 12:26 am | |
Hopefully it looks better when i groove the knobbys. youll see. I have some more junk ill be able to get done to this, its going to be above freezing for majority of next week! Shop time still gonna be juek | |
| Subject: Re: MTD off-road romper build. March 9th 2015, 6:50 am | |
| - TheBeal wrote:
- So tell me... Whats your thread page goal for this?
Page number goal? Oh, I don't have a goal. It just....happens | |
| Subject: Re: MTD off-road romper build. March 9th 2015, 8:56 pm | |
| Ah so more progress from the past week and today. High steer, wanted to get this done. Took the old bar, cut the spindle steer arm ends off, turned the tie rod 180 and flipped it upside down. Gained about 3" of clearance. Im thinking building a bumper almost on the axle that drops down and protects the tie rod when i hit rocks or the tire slips off the rock and ends up inbetween the tires. Tie rod ends are pretty automotive type. have to use a ball joint separator to remove the tie rod. Have grease zerks too. Original setup: Cut and moved them up. Used 1/4" plate. Tie rod really tucked into the rim as much as possible. Excuse the trash welds where I think i can weld over my tack welds Modded the steering stops. Pretty easy. End result. Much better. Onto the Arctic cat brakes. All this time i thought i was putting them on the axle. Silly me, didnt even check if that honkin' 8" rotor would fit, and it didnt... Buy a mile... Plan B (or only other option) imput shaft brake. Maybe this is a first? For vertical shaft trannys at least. Put the rotors hub on a lathe, re faced it, and bored it within thousands to my pulleys shaft. Took a long time of tack weld, spin the pulley and rotor, tap it with a hammer, spin more, tap more, even spun it with a drill. I think i got it within 30 thousands. Aint perfect by any means but its damn good for me. After i was done with that, i mounted the caliper all the way back in the corner. after a bunch of cutting, grinding, close measurements, careful bolt hole drilling, i made a bracket for the caliper. All together. Took a lot longer then pictures say it did, but i feel like it will work good. I put a hole in the side of the frame for the snowmobile brake handle cable. I think ill mount it on the fender to the left of me. Has a parking brake on it too. | |
| Subject: Re: MTD off-road romper build. March 9th 2015, 9:41 pm | |
| Keeps the tie rod up out of the way a lot better. Actually a neat spot for the brakes since it's protected in there from hitting junk or water splashing onto it. Mostly anyway. I'd say rugged enough to put the brakes on the trans when your only going like 20mph max.
rarbaugh07 Member
Age : 35 Join date : 2014-01-22 Points : 3868 Posts : 117 Location : Logan, iowa
| Subject: Re: MTD off-road romper build. March 10th 2015, 11:14 pm | |
| Pinion brake only so no brakes in neutral then or also regular brakes? And is it finally warming up in NY cause I can't wait to see that thing out wheelin. | |
| Subject: Re: MTD off-road romper build. March 12th 2015, 2:37 pm | |
| - rarbaugh07 wrote:
- Pinion brake only so no brakes in neutral then or also regular brakes? And is it finally warming up in NY cause I can't wait to see that thing out wheelin.
Yea no Nutrel brakes but I don't think it's a big deal. I DID wheel all last year with no brakes at all. And thanks, close to driving it but don't have to much cash. All in pay pal. | |
MurrayMayhem Member
Age : 24 Join date : 2013-01-03 Points : 4249 Posts : 99 Location : 820 Opposed Twin RD. AxleBreaker City
| Subject: Re: MTD off-road romper build. March 12th 2015, 4:34 pm | |
| thats a great brake idea. It just seems apretty big for the input shaft. I've broke alot of those things by dumping the clutch, lol. | |
Doc Sprocket Site VIP
Age : 51 Join date : 2013-04-21 Points : 7109 Posts : 2914 Location : Ontario Canada
| Subject: Re: MTD off-road romper build. March 12th 2015, 9:23 pm | |
| - MurrayMayhem wrote:
- thats a great brake idea. It just seems apretty big for the input shaft. I've broke alot of those things by dumping the clutch, lol.
Maybe if i had a lathe big enough id turn a inch off the rotor but whatever. Brakes alone is a luxury in the offroad mower world. Thanks Doc. I could have this driving by this week but i got a bunch of money tied up on other junk. Playing the waiting game. Need junkyard parts, belt, and idler pulley. | |
| Subject: Re: MTD off-road romper build. March 16th 2015, 9:48 pm | |
| I don't think you'll run into much trouble with brakes working too good, as in grabbing or anything. Wouldn't be too hard to fix if you did. | |
| Subject: Re: MTD off-road romper build. March 16th 2015, 10:29 pm | |
| Dee doo, more stuff done. Clevis yo! Next is skid plate, mocked up here form a 22x16" piece of 1/8" I knotched and bent up 2 bolts holding it up front and 2 in the back. Gusseted the frame so the "hitch" plate doesnt bent up. Bunch of snowmobile junkyard heims. All are in aluminum tie rods so the smaller ones break, witch is stupid. i managed to save a few of em, and some of the broken ones it doesnt matter if its broke. Shifter time. Modded the stock Murray nut buster shifting extension, and used a heim to support it at the top. Made some linkage and arms up, the actual rod that goes thru the frame rails is 5/8" this time, not the dinky 1/4" i used last time, bent up and eventually broke. Gusseted the shifting arm, and used 1/4" plates drilled out 5/8" so the rod has something to move on, and wear on when moving. Also, i deleted my old sidepipe holes in the running board. Looks way better. Threw some hood pins on the top of the grill "pipes" and drill the hood. Race mower. | |
Age : 36 Join date : 2013-07-02 Points : 4810 Posts : 731 Location : Logan Ohio
| Subject: Re: MTD off-road romper build. March 17th 2015, 7:49 am | |
| looking good redline! I love how much though you put in everything on your builds. Your also finding its easyer to gusset and overbuild, then to bend up weak stuff and try to fix it later. Great work | |
802 Customs Member
Age : 24 Join date : 2015-01-08 Points : 3549 Posts : 146 Location : Vermont
| Subject: Re: MTD off-road romper build. March 17th 2015, 3:18 pm | |
| Still just a jenk MTD. Lol, great job though. Must be nice to have a mig, such clean welds.
| Subject: Re: MTD off-road romper build. March 17th 2015, 4:07 pm | |
| - Creepycrawler wrote:
- looking good redline! I love how much though you put in everything on your builds. Your also finding its easyer to gusset and overbuild, then to bend up weak stuff and try to fix it later. Great work
Thanks, and yea I have. Really takes the fun out of things when it isn't working right or performing to it's fullest. - 802 Customs wrote:
- Still just a jenk MTD. Lol, great job though. Must be nice to have a mig, such clean welds.
lol, and yea I love it. Maybe later in life I can pic up a everlast 256 deal. $1,600 isn't in the budget at the moment | |
802 Customs Member
| Subject: Re: MTD off-road romper build. March 17th 2015, 7:46 pm | |
lol, and yea I love it. Maybe later in life I can pic up a everlast 256 deal. $1,600 isn't in the budget at the moment After 2-3 weeks working this summer I should be able to afford a mig and a tank of c25, then I can use it all summer long. Its hard to find a job at 15 in VT because the minimum wage is so high ($9.15), I'd already have a mig if somebody would hire me. I have put like 1 pound through my TSC brand flux core and I really hate it, the slag is unreal, and I'm kind of a perfectionist so it pisses me off how junk my welds look on flux core. | |
98svtcobra Member
Age : 39 Join date : 2014-04-30 Points : 3769 Posts : 110 Location : Mahopac, NY
| Subject: Re: MTD off-road romper build. March 18th 2015, 3:30 pm | |
| Damn man! Looks awesome. I can't believe the transformation this thing has gone through! | |
Carshowkid Member
| Subject: Re: MTD off-road romper build. March 18th 2015, 4:19 pm | |
| - 98svtcobra wrote:
- Damn man! Looks awesome. I can't believe the transformation this thing has gone through!
wheres throw back Thursday when you need it? | |
| Subject: Re: MTD off-road romper build. March 18th 2015, 10:06 pm | |
| - Carshowkid wrote:
wheres throw back Thursday when you need it? Tomorrow, of course. | |
