| | Custom Snorkel for Craftsman | |
Nico K New Member
Join date : 2013-07-26 Points : 3956 Posts : 16 Location : southern NH
| | | | Doug Site Owner
Age : 28 Join date : 2012-12-24 Points : 7561 Posts : 3035 Location : Lebanon County, PA
| | | | Nico K New Member
| | | | Doc Sprocket Site VIP
Age : 51 Join date : 2013-04-21 Points : 7110 Posts : 2914 Location : Ontario Canada
| Subject: Re: Custom Snorkel for Craftsman December 7th 2013, 9:27 am | |
| You basically have two choices- get rid of the lower half of that filter box and mount directly to the carb, or put the upper box back on, make a hole in it, and mount to that. Either way, you've got a bit of fab work ahead of you. Whatever you do, fint a way to incorporate a filter into the design. | |
Age : 27 Join date : 2013-04-10 Points : 5553 Posts : 1408 Location : Galway NY
| Subject: Re: Custom Snorkel for Craftsman December 7th 2013, 11:25 am | |
| x2 on what doc says. cut a hole with a holesaw on a drill, just a tad smaller and you could probably thread a piece in or make a flange or something. i would go this route so you dont have to re-locate the air filter too | |
| | | jack9102 Member
Age : 27 Join date : 2013-03-17 Points : 4204 Posts : 103 Location : Sudbury, ON, Canada
| Subject: Re: Custom Snorkel for Craftsman December 7th 2013, 11:53 am | |
| you can't just knock a hole in the upper airbox cover, pipe it, and have it be waterproof/resistant. The underside of these boxes is full of holes, just like 3 - 4hp mower engines with tank top carbs. The same goes for both foam and paper filters. Taking the entire two piece assembly off will give you a better idea how to waterproof it and plumb up a schnoerkel.
I'd suggest covering the bottom holes with JB-Welded vent duct sheet metal, making sure you got all the holes covered, then smear a bead of weatherproof silicone around the perimeter of the plate. After that I'd do as everyone else is saying, put a pipe out of the top half of the box. I'd suggest leaving the filter element in the box so any crud in your pipe wont be breathed, but a secondary filter on the pipe end wouldn't hurt.
Now that I think of it though, the seal between the top and bottom airbox halves isn't exactly water tight, let alone air tight, so you might just end up putting pipe on the carb flange where the box meets it. in that case I'd drill a hole in the back of a 90* elbow, so I can somehow use the original airbox screw to hold it on the carb, silicone seal it to the carb, and run rubber pipe from that. | |
| | | jack9102 Member
| Subject: Re: Custom Snorkel for Craftsman December 7th 2013, 1:02 pm | |
| WAIT NO I F'd UP
Your engine has the newer style airbox. flat plastic bottom, plastic box upper, with a paper element. In your case you'll just end up making a flange going to the carb inlet and running pipe from there. Remove your airbox lower half, and you'll be left with a bare opening of the carb, the choke plate will be right there. Make a plastic two bolt flange to go where the airbox outlet was, stick a plastic pipe section [approx. 1" long] on the flange, bind the two together and run rubber hose to where you want your air inlet. I prefer rubber hose for snorkels cause vibration won't loosen glue joints and you can run it anywhere you can secure it with a gear clamp. My last post only applies to older engines with stamped steel air boxes.
One downside to this is you'll have to find a new way to operate your remote choke [if you have this mod], since the plastic airbox lower half has the mount point for the cable.
Age : 27 Join date : 2013-03-18 Points : 7275 Posts : 3131 Location : raleigh nc
| Subject: Re: Custom Snorkel for Craftsman December 7th 2013, 1:06 pm | |
| You could use that part that you show in the pic, fit a PVC pipe over the holt that leads to the carb, and jd weld it there. cu the rest of it off and just go off the PVC you put on there. | |
| | | Nico K New Member
| Subject: Thanks! December 22nd 2013, 4:00 pm | |
| Thanks for all the help! I think ill cover up all the holes in the top peice and drill a hole with the hole saw! | |
| Who is online? | In total there are 34 users online :: 0 Registered, 0 Hidden and 34 Guests
