Hi all though I might share some pictures and videos of the wife’s tractor in here Here’s a video explaining the tractor and the recovery https://youtu.be/5aLQ7UP8NNk
Now it’s been a great little tractor but she’s really enjoying it more than I tough she would so I decided to do some upgrades, the 801 was fine but the low gear wasn’t really slow enough for crawling, so I’m swapping in a 820, which will also be faster in top gear, gonna go from 21 inch rears and 15 fronts to 25 rears and 20 inch fronts, at the same time stretching the wheel base and making the tractor wider, which will be more stable. Gonna upload some pics later on too show the progress later
Age : 36 Join date : 2013-07-02 Points : 4811 Posts : 731 Location : Logan Ohio
Here’s a few pics of the lift and stretch I did to get the 25s to clear the fenders, 3/4 stretch and 1 1/4 lift Chopped the trans mount here, slid it down and back and added a filler piece to make up the difference
Buffed the welds off the outside, so it will look factory at first glance, left the inside welds alone to help with strength
Well now the tire clears the front and top of the fender but the rear lip is hitting hard, I could have cut the back lip off but it would have looked funny to me so I decided to section the fenders Before
After
Mocked up with the rack that’s going on the back, I’ll have to modify the rack but I think it’s gonna look good.
fbisurveilancevan Member
Age : 37 Join date : 2022-05-20 Points : 949 Posts : 220
Worked as a JD tech for a long time and I can't express my hatred for the newer models.
These older ones however just hit the right spot. Those fenders look amazing like so and those tires just fit perfect Might be a pain if they're full of mud though, are you perhaps still lifting the pan a little?
Thanks man! This thing is built pretty good for being a lawn tractor, but I’m not lifting the fenders anymore than they are, I don’t mind if mud touches em, it will just rub off Got the trans pulled apart to lock the diff
Was really sad to see the shift keys was trashed the tractor I bought that I took this 820 out of was a Murray in really nice shape that came with a snow plow, not running. So I’d guess they was overly aggressive and tore up the keys plowing
Decided to try a “Fozzy” locker, cleaned up the gears and then tig brazed up the gears
Got the frame chop started, took the spare frame and got the extension pieces cut
Built this hub puller to help get hubs off without breaking them, took these hubs right off, and they were stuck, had a 2 ft breaker bar and was leaning on it pretty hard
Thanks Fellas! I really like the fenders too, came out better than expected to be honest, but decided to do them a little different, they will look the same when done it’s just less welding and fitting. I felt pretty clever with the name, glad you like it too Mighty. Got some work done today on it
Got the outside welds ground down
Quick coat of primer
And some black to finish
Cut the pan for the mid stretch, did 2 inches same as the frame Got some filler pieces bent up, they was a real pain because the pan tapered slightly and has a different radius at the spot I cut it (right in a transition) but tomorrow should be fairly easy the rest is just copy and paste out of the donor pan
Got the rear filler unrolled and tacked in, felt pretty clever doing it this way, but turned out being a big pain in the but because I didn’t flatten it before I welded the extension on, so I had to use to hammers one as a backer kinda and pound it flat, took a long time to get a decent result but I am happy with it now
Sweet looking booty if I do say do myself 🥰
Now on to the seat mounts!
Seat mocked up with the mounts, still needs drilled so the seat can flip up, ended up trying a few seat pan flip mounts laying around, but had one off a wheel horse that her seat bolted right up to, so went with that one. I could have reused the leaf type springs but I really wanted a flip up seat so I can add a storage box under there for her
Mock up pic with the rack and seat definitely gotta cut the rack down some but it’s gonna fit nice
The seat mounts were kinda big and bulky so I drilled some speed holes in em. It was going good till somehow my math got off and the spacing got out of whack, and I went a step to far on the step bit once like every time I used the dam thing lol but thats ok it still looks ok and I don’t feel like remaking them so it will have to be good enough .
diddie Member
Age : 56 Join date : 2016-10-02 Points : 3222 Posts : 411 Location : Indiana
Does that add 5 or 10 horsepower? I forget lol. Looks awesome!
Thanks guys! I’m thinking it adds at least 4 hp and I don’t know if patient is the right word, I’d go with stubborn anyways I got the mounts and springs in tonight, need yo add some bracing underneath for the springs but that will be a project for tomorrow Got the seat mounted tonight, it’s a little higher than I like but it’s more work to lower it than I care to do due to the springs, but if it becomes a issue I can lower it later by drilling a couple holes and then frenching the spring mounts into the pan. Need this add some bracing under the springs on the frame but that’s. Project for tom
diddie and Brianator like this post
So the front axle needed to be wider to get a decent steering angle out of the new much bigger front tires and also to match the new stance of the rearend. I decided to make it a “stretch” axle to add a little wheel base up front to help keep the frontend down also. So I took two factory front axles and started cutting
