 first built but not the last
steeldaytonas
steeldaytonas
first built but not the last Empty
PostSubject: first built but not the last   first built but not the last Icon_minitimeDecember 5th 2015, 9:38 pm
this is my first tactor offroad built it running but not trail ready.
first built but not the last Img_9519first built but not the last Img_9520first built but not the last Img_9521first built but not the last Img_9522
PostSubject: Re: first built but not the last   first built but not the last Icon_minitimeDecember 5th 2015, 10:26 pm
Tell the folks how you made those front hubs.
steeldaytonas
steeldaytonas
PostSubject: Re: first built but not the last   first built but not the last Icon_minitimeDecember 5th 2015, 10:49 pm
yea Im made by hand but its a 2'' round stock with 3/4'' hole made on a lathe welded on a 1/4'' plate . I align all the holes on the plate including the center hole and use a 3/4'' bolt to align the plate and the round stock together and finished by weld it square. I made the rear hub on the same way but I had few threaded hole to put locking bolts who are align with the original channel key of the axle shaft.
I will send some more pics soon. I have to disassemble it to do the fine work one it because now I just done the preliminary built the make everything work and fit together so I will take good pics for you guys
steeldaytonas
steeldaytonas
PostSubject: Re: first built but not the last   first built but not the last Icon_minitimeDecember 12th 2015, 8:40 pm
some more pic: the carb, gas pedal and rear and front hubs. The bolts who lock the hubs on the rear shaft may looks overkill but I realy whant to avoid the shaft slipping in the hubs . So 4  1/2inch bolts are tight in 4 light knoch on the shaft and 4  1/4 bold are lock in the chanel of the shaft
first built but not the last Img_9611
first built but not the last Img_9610
first built but not the last Img_9612
first built but not the last Img_9613
first built but not the last Img_9614
first built but not the last Img_9523
steeldaytonas
steeldaytonas
PostSubject: Re: first built but not the last   first built but not the last Icon_minitimeDecember 13th 2015, 4:11 pm
first built but not the last Img_9622
first built but not the last Img_9623
PostSubject: Re: first built but not the last   first built but not the last Icon_minitimeDecember 14th 2015, 7:14 pm
Nice. What kind of lathe do you use? I'm just starting to look into buying one.
steeldaytonas
steeldaytonas
PostSubject: Re: first built but not the last   first built but not the last Icon_minitimeDecember 14th 2015, 7:36 pm
hum I use the one at my job so I have to look the brand but ruffly its mid size professional machinist lathe it could handle 6'' round stock on about 4foot long. Im not a pro with machining but I know enough to do what I need, sorry if its not super accurate info
PostSubject: Re: first built but not the last   first built but not the last Icon_minitimeDecember 14th 2015, 8:31 pm
Sounds like about the size that would handle pretty much anything I plan on working with.
steeldaytonas
steeldaytonas
PostSubject: Re: first built but not the last   first built but not the last Icon_minitimeDecember 15th 2015, 7:28 am
pretty much yes we have it in a military shop to provide support to the vehicle maintainer
steeldaytonas
steeldaytonas
PostSubject: Re: first built but not the last   first built but not the last Icon_minitimeDecember 19th 2015, 3:26 pm
the first ride with my first built it run like a charm . But still a lot of work to put on it
first built but not the last Dscf2910first built but not the last Dscf2911
steeldaytonas
steeldaytonas
PostSubject: Re: first built but not the last   first built but not the last Icon_minitimeDecember 19th 2015, 3:39 pm
what have to be fix:
loose in steering system
better fender trim
enlarging front axle and rubbing trim
air filter
carb adjust
tranxle rebuilt
finish batterie rack
add hood lock
mod I want to had:
alternator
light
larger seat (to sit my son with me)
locking rear axle
winch
bumper
rear rack
adding bearing on front hub
adding electric fan
Radio and cup holder
steeldaytonas
steeldaytonas
PostSubject: Re: first built but not the last   first built but not the last Icon_minitimeDecember 19th 2015, 3:57 pm
steeldaytonas
steeldaytonas
PostSubject: Re: first built but not the last   first built but not the last Icon_minitimeDecember 19th 2015, 4:27 pm
steeldaytonas
steeldaytonas
PostSubject: Re: first built but not the last   first built but not the last Icon_minitimeMay 18th 2016, 7:12 pm
3h of offroading after an hard day of dealing with hard familly stuff
first built but not the last Img_0816
first built but not the last Img_0821
first built but not the last Img_0817
first built but not the last Img_0820
first built but not the last Img_0819
first built but not the last Img_0818
first built but not the last Img_0822
first built but not the last Img_0824
first built but not the last Img_0823
PostSubject: Re: first built but not the last   first built but not the last Icon_minitimeMay 19th 2016, 8:38 pm
Still in one piece huh? Are those front wheels cragers? I have a set of 4 of those with some rust. Didn't find any use for them yet though.
steeldaytonas
steeldaytonas
PostSubject: Re: first built but not the last   first built but not the last Icon_minitimeMay 19th 2016, 9:50 pm
yeap still in one piece but still some stuff to improve like brake, steering, intake and the accesories.
and yeap hteyr cragar I have the rear one to but I have a problem to fit them due to the shifter position so I try to figure it out
I think I plan enough stuff to do on it to put it in the built contest but I still have a lot to do on my Overkill built
» Anyone ever built one of these?
» Troy built big red help
» Home built RAGB
» My nephews trike I built
» All of the monster mowers I have built.
