| 73 sears workhorse/mudder | |
+15Dr Bob Rustbucket Garage Hillbilly Offroading mowerjunkie03 MatthewD mr.modified CraftsmanQuad19 RichieRichOverdrive TheBeal prancstaman Double W Cross Ranch Crazy_Carl MightyRaze AllisKidD21 Buck 19 posters |
Buck Member
| Subject: Re: 73 sears workhorse/mudder March 19th 2018, 11:01 pm | |
| - AllisKidD21 wrote:
- Is the valve lash adjustable on those Tecumseh's like the old K Series Kohlers were?
Looks like a Tecumseh flattie. Yeah I know that's why I was asking. He mentioned checking the valve lash so I was curious if it was adjustable like the K Series flatheads were. They had adjustable tappets which is pretty handy.
no there not adjustable, you have to pull the valve and grind it down to spec, i just did my 10hp snowblower tonight made a big difference | |
Age : 49 Join date : 2016-09-06 Points : 15089 Posts : 10654 Location : Oklahoma
prancstaman Veteran Member
Join date : 2015-02-02 Points : 4899 Posts : 1412 Location : Cleveland,Ohio
| Subject: Re: 73 sears workhorse/mudder March 19th 2018, 11:12 pm | |
| - MightyRaze wrote:
- Does an old Tecumseh have a compression release of sorts?
On the vertical shaft engines, that have the oil pump driven off the cam. When the engine is not running and no oil pressure, that is when the compression release is on. It is on the cam exhaust lobe. The cam is hollow and a pathway for the oil to the whole engine. When the engine is cranking to start, it dumps compression out the exhaust a few revolutions, enough to get the engine spinning and to fire. when the engine fires, usually when the oil pressure is at max, the easy start rod on the cam lobe disengages and you get full compression. If the engine doesn't fire or start then the easy start won't disengage. The oil pump will only supply enough oil to disengage it when running. On a horizontal shaft Tecumseh, IDK if it has this setup or a different kind of setup. But does need the rpm of engine running to disengage it, and cranking rpm usually isn't fast enough. | |
Buck Member
Join date : 2017-11-01 Points : 2685 Posts : 282 Location : Eastern Ontario
| Subject: Re: 73 sears workhorse/mudder March 19th 2018, 11:17 pm | |
| I have read something about that before about cranking speed, ill hook up my booster to it and see if it makes a difference. i still need to do the valves you can hear it leaking and i have to pull the head to do it, might aswell clean the ports up and new head gasket | |
| Subject: Re: 73 sears workhorse/mudder March 19th 2018, 11:33 pm | |
| Might work with the booster, get it spinning as fast as you can. Since you are going to pull the head, best time to check to see if it has the easy start on it. By seeing if the exhaust valve will spin on the compression stroke (the whole stroke), and the intake stroke (the whole stroke) for a comparison. If the valve spins any on the compression stroke then you know for sure it has the easy start on it. If it spins on the intake stroke any then you know the valve is out of adjustment. The valve should not spin by hand if seated correctly on the seat. Basically putting finger on the edge of the valve and trying to spin it for the test. | |
| Subject: Re: 73 sears workhorse/mudder March 19th 2018, 11:35 pm | |
| Good information prancstaman. I didn't realize those older engines were that complex. | |
| Subject: Re: 73 sears workhorse/mudder March 20th 2018, 12:13 am | |
| - MightyRaze wrote:
- Good information prancstaman. I didn't realize those older engines were that complex.
Thanks. The Tecumseh engines had the pressure lube on the vertical shaft engines, I started noticing that on the 80's and late 70's engines, when Briggs was using the oil flingers on theirs. But I see alot of down talking on the Tecumseh motors though, even though mostly everything else is the same except how they balance the crankshaft. I'd rather have a Tecumseh then a Briggs. Torque motors they are. | |
Crazy_Carl Veteran Member
Age : 35 Join date : 2017-10-30 Points : 5136 Posts : 2561 Location : Rochester, New York
| Subject: Re: 73 sears workhorse/mudder March 20th 2018, 9:17 am | |
| @prancstaman Man you have so much good engine knowledge hidden away in that brain of yours. Don't be surprised if I contact you for engine help one day. @Buck Mault Thank you for keeping your ole tecumseh alive and not running to princess auto to buy a clone motor on sale. I think a good ole tractor with a good ole motor is just awesome. Contrary to what my signature says I really like your sears. I like following your detailed build thread about it. In many ways your 73 sears build mirrors my 79 wheel horse build in a few ways: we're running the original engines (believe it or not that's not the original engine in Ol Red, but a direct replacement someone put in a long time ago), we use our tractors for work and play, our body work is pretty close to original, we upgraded the lighting, we've re-wired our tractors (isn't it nice knowing where every wire goes to?), we've upgraded the tie rods, we put on a better set of tires, and both tractors are just plain built great right from the factory. In a couple of ways your tractor is better. You have a front bumper and a skidplate. I have front bumper plans and I've thought about building a nice lower belt guard/skid plate, but lately I'm trying to focus on my build off tractor. Are you going to pulley swap your sears? | |
Buck Member
| Subject: Re: 73 sears workhorse/mudder March 20th 2018, 1:01 pm | |
Thanks. The Tecumseh engines had the pressure lube on the vertical shaft engines, I started noticing that on the 80's and late 70's engines, when Briggs was using the oil flingers on theirs. But I see alot of down talking on the Tecumseh motors though, even though mostly everything else is the same except how they balance the crankshaft. I'd rather have a Tecumseh then a Briggs. Torque motors they are. Thank you for the info, thats one of the things i like about the group Cheers @Crazy_Carl, thanks alot man. That was my plan for this tractor was to keep it close to origanal, everything bolt on so i can use implements with it, but change out the weak points, this engine will get a rebuild at some point. for a pulley swap i would like a little more speed in hi so i was going to a 6" on the rear and a 5" on the engine, i want to keep the rear pulley as big as possible so i have more surface area for the belt( less slippage) the Biggest things i need to do is get better tires for the rear, maybe lock it, fix the front grill, better foot throttle. and then a full paint job. i like how yours is Turned out as well, I like to keep one close to original. but the other sears is not going to stay original lol I hope one day I find a 79 Wheel horse. | |
Buck Member
Buck Member
| Subject: Re: 73 sears workhorse/mudder March 20th 2018, 8:03 pm | |
| that looks like a fun trail. It’s interesting that your tractor kind of sounds like a diesel | |
Buck Member
| Subject: Re: 73 sears workhorse/mudder March 20th 2018, 8:22 pm | |
| @Crazy_Carl that is not always a good thing lol, i usally never ham on it only in high gear, i use too offroad alot building, breaking , fixing, repeat. i like to crawl but want speed if needed | |
Buck Member
Age : 20 Join date : 2017-06-09 Points : 5295 Posts : 2640 Location : Literally Nowhere, Texas
Buck Member
| Subject: Re: 73 sears workhorse/mudder March 21st 2018, 12:11 pm | |
| ya its beefy, I over did it on it, but its good. I went this route so I can put on the back what ever I just need to add a 2'' hitch to it | |
Buck Member
| Subject: Re: 73 sears workhorse/mudder March 21st 2018, 12:14 pm | |
| When I got Frankin Sears a blade came with it, no mounts, and in great shape just like the tractor lol, i build a mount for it, made it so it can hook into the factory rear deck mount. i dont have a winch yet so its a strong arm lift. and its a workout. [url=https://servimg.com/view/19809240/61 [/url] | |
Age : 25 Join date : 2016-07-10 Points : 8390 Posts : 5190 Location : Ontario Canada
| Subject: Re: 73 sears workhorse/mudder March 21st 2018, 12:22 pm | |
| Nice blade mounts! So is that big pole on the right hand side of the tractor for extra leverage? I've been wondering about that, haha. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
Buck Member
| Subject: Re: 73 sears workhorse/mudder March 21st 2018, 12:25 pm | |
- Nice blade mounts! So is that big pole on the right hand side of the tractor for extra leverage? I've been wondering about that, haha.
Exactly lol for now until I get a winch. it just slides over the lever that engages the front pulleys | |
Buck Member
| Subject: Re: 73 sears workhorse/mudder March 21st 2018, 12:28 pm | |
- Haha, like the smilie! Can that clear weeds/small trees/rocks?
lol Always nice when a neighbor shows up and plows your driveway. haven't tried yet but it does push gravel, that's why I mounted it so far back the angle of the blade is more flat pushing not digging in. I want to find or build the original dozer blade sears had back in the 70s | |
Buck Member
Buck Member
Buck Member
| Subject: Re: 73 sears workhorse/mudder March 21st 2018, 1:04 pm | |
| is that a newer sears blade? that's a clean looking grill, this blade is only temp , the front is wore out | |
