| 82 Mudskee | |
+4MightyRaze Crazy_Carl AllisKidD21 Buck 8 posters |
Buck Member
Join date : 2017-11-01 Points : 2674 Posts : 282 Location : Eastern Ontario
| Subject: 82 Mudskee August 21st 2018, 2:19 pm | |
Buck Member
Age : 25 Join date : 2016-07-10 Points : 8379 Posts : 5190 Location : Ontario Canada
| Subject: Re: 82 Mudskee August 21st 2018, 2:47 pm | |
| That my friend, is a good ol' Peerless 2300! Definitely one of the better garden tractor transaxles as far as being heavy duty goes, and yours has the sweet disk brake setup as well! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
Buck Member
| Subject: Re: 82 Mudskee August 21st 2018, 3:04 pm | |
| ya its beefy brakes, free tractor on the side of the road lol, 16hp twin, the only thing I found wrong was it was grounding the coil out no spark easy fix
Crazy_Carl Veteran Member
Age : 35 Join date : 2017-10-30 Points : 5125 Posts : 2561 Location : Rochester, New York
| Subject: Re: 82 Mudskee August 21st 2018, 3:15 pm | |
| What an awesome free find! Great start to a project. All of AllisKidD21's rigs started out as free finds and so did my John Deere. I passed a free sabre on the side of the road last week. Spicer rear end and a wet noodle pan frame so I just kept driving lol. | |
Buck Member
| Subject: Re: 82 Mudskee August 21st 2018, 3:40 pm | |
| Is has belt twist and a pan frame of some sorts, but it's a neat old looking Huskee with an oppy and a 2300! How's the steering in it? | |
Age : 49 Join date : 2016-09-06 Points : 15056 Posts : 10634 Location : Oklahoma
| Subject: Re: 82 Mudskee August 21st 2018, 4:25 pm | |
| Interesting find! Looks like fun! | |
Buck Member
MatthewD Veteran Member
Age : 22 Join date : 2014-11-16 Points : 5545 Posts : 1993 Location : Northern Ireland
| Subject: Re: 82 Mudskee August 21st 2018, 5:13 pm | |
| Wow, great that you got it for free. I'd say it was made by Dynamark, yours looks like a Dynamark 16/42. That 2300 is really heavy duty, the disk brakes are really cool. | |
Buck Member
| Subject: Re: 82 Mudskee August 21st 2018, 5:41 pm | |
| might as well make a build thread about it, can you guys move it to offroad section and call it MudHuskee. cheers thanks gents | |
Buck Member
| Subject: Re: 82 Mudskee August 21st 2018, 5:43 pm | |
| @MatthewD I'll look into it, ya its beefy. I'm not going to paint it leave it as is maybe some clear coat I like the patina look | |
| Subject: Re: 82 Mudskee August 21st 2018, 5:52 pm | |
| - Buck wrote:
- might as well make a build thread about it, can you guys move it to offroad section and call it MudHuskee. cheers thanks gents
Gotcha covered, again. LOL. Pretty cool that you got 'er for free, definitely a good score. Got any plans as far as mods or is that all still up in the air? "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
Age : 20 Join date : 2017-06-09 Points : 5284 Posts : 2640 Location : Literally Nowhere, Texas
| Subject: Re: 82 Mudskee August 21st 2018, 5:56 pm | |
| Nice tractor there, little rusty, but I like that. Being a pan frame, do you plan to reinforce it any? | |
Buck Member
| Subject: Re: 82 Mudskee August 21st 2018, 6:27 pm | |
| @AllisKidD21 thanks. Still up in the air until I know for sure the transaxle is good to go but probably ATV tires on rear bigger up front foot throttle hand brake bumpers, winch lights front and rear reinforce the frame is a must this one will be for friends when there over and all that rust is just surface more like sun baked or get it driving and use it. then wait until the next build off before I start building it | |
Age : 23 Join date : 2016-04-12 Points : 5747 Posts : 2619 Location : Indiana
| Subject: Re: 82 Mudskee August 21st 2018, 6:34 pm | |
| That huskee is actually made by dynamark | |
Buck Member
Buck Member
| Subject: Re: 82 Mudskee August 22nd 2018, 1:51 pm | |
| had it driving today I guess it's a keeper | |
| Subject: Re: 82 Mudskee August 22nd 2018, 7:17 pm | |
| Yes! Do all the gears work? How does the oppy run?
So how about the name "MudSkee"? | |
Buck Member
| Subject: Re: 82 Mudskee August 22nd 2018, 7:37 pm | |
| @Crazy_Carl I have to figure out the governor and throttle set up on this 16 its a little different then the 18, I just bypassed the governor and hook the throttle straight to it, ran great. as for the transaxle the gear oil was mint and every gear work great. not a fan of the clutch on the right with the brake there too, the damn brake lock engaged when I was shifting into high gear and then it let go and I popped the front straight up the only thing that stop me from going over was the hitch lol. I like that name let's change it | |
| Subject: Re: 82 Mudskee August 22nd 2018, 7:50 pm | |
| Go back to your original post and click edit. You can change the title there if you like. | |
| Subject: Re: 82 Mudskee August 22nd 2018, 7:56 pm | |
| Glad you like the name.
Sounds like building a clutch pedal on the left should be one of your first mods. | |
Buck Member
| Subject: Re: 82 Mudskee August 22nd 2018, 8:34 pm | |
| @Crazy_Carl ya maybe but due to being a belt twist the belt is more to the right side of the tractor then the center, I'll have to look at it more | |
| Subject: Re: 82 Mudskee August 22nd 2018, 8:52 pm | |
| The clutch on mine and redzz02’s dynamarks are all on the right side | |
Buck Member
| 82 Mudskee | |
