| 82 Mudskee | |
+4MightyRaze Crazy_Carl AllisKidD21 Buck 8 posters |
Buck Member
Buck Member
Join date : 2017-11-01 Points : 2685 Posts : 282 Location : Eastern Ontario
| Subject: Re: 82 Mudskee September 29th 2018, 4:29 pm | |
| engine swap time, 16hp yo a 18hp but now I have 4 reverse gears and one forward lol, can you guys with dynamark with a belt twist set up post up a pic
Buck Member
MatthewD Veteran Member
Age : 22 Join date : 2014-11-16 Points : 5556 Posts : 1993 Location : Northern Ireland
| Subject: Re: 82 Mudskee September 29th 2018, 5:36 pm | |
| Nice power upgrade. Are you sure that both engines turn the same way? | |
Buck Member
Crazy_Carl Veteran Member
Age : 35 Join date : 2017-10-30 Points : 5136 Posts : 2561 Location : Rochester, New York
| Subject: Re: 82 Mudskee September 29th 2018, 10:03 pm | |
| If I had to guess the belt needs a twist in it to change direction of rotation on the input shaft. Did the tractor have a belt when you got it? | |
Age : 49 Join date : 2016-09-06 Points : 15090 Posts : 10655 Location : Oklahoma
| Subject: Re: 82 Mudskee September 29th 2018, 10:48 pm | |
| Looks to be the same orientation as my tractor Kal's.
Edit: That is NOT how my mower's belt is ran. Looks to be running the transaxle the wrong way. I will edit or post that belt diagram soon.
| Subject: Re: 82 Mudskee September 30th 2018, 1:25 am | |
| Hope this diagram helps!! | |
| Subject: Re: 82 Mudskee September 30th 2018, 5:03 am | |
| I think I finally figured this out he put a twist in the belt that is not supposed to be there. The belt coming from the trans pulley needs to route to his clutch pulley. He twisted the belt which you can see in those pictures so the belt is coming from the trans idler pulley and going to the clutch pulley which reverses directions. Took some staring at his pictures and this diagram to figure this out but luckily this should be an easy fix. that’s a great diagram @MightyRaze | |
Buck Member
| Subject: Re: 82 Mudskee September 30th 2018, 11:34 am | |
| @Crazy_Carl @MightyRaze thanks guys ya it ended up I had to 180 the belt on the trans, from clutch to top of transaxle pulley not the other way, I laugh hard when I went to test it and almost reversed into my truck. because so use to pushing in the clutch with the left foot I slammed on the gas instead | |
Buck Member
| Subject: Re: 82 Mudskee September 30th 2018, 6:11 pm | |
| does anyone know how to fill these transaxle, no fill plug. maybe through the shifter? | |
| Subject: Re: 82 Mudskee September 30th 2018, 9:34 pm | |
| Drain is on bottom. You can see it in this pic of yours. Between that plug and the shifter should be another plug. Unfortunately that I believe is the fill hole. 2300 64 oz./1892 ml 80W90 Oil | |
Buck Member
| Subject: Re: 82 Mudskee October 1st 2018, 4:09 pm | |
| @MightyRaze lol yes but there is no fill plug, I was just wondering if you fill it from the shifter, I used to to that with older trucks it was easier just seeing if this is the same | |
| Subject: Re: 82 Mudskee October 1st 2018, 7:48 pm | |
| I'd use the shifter hole. How hard is it to access?
When I locked the rear end in ol red I never even took the fill plug out. I filled if through the shifter hole so I could squeeze the bottle of gear lube to get the oil in in seconds instead of an hour. However the trans was outside of the tractor when I did this. | |
Buck Member
| Subject: Re: 82 Mudskee October 1st 2018, 8:08 pm | |
| @Crazy_Carl exactly, it's not in a bad spot I still need to run a hose but at least it will be easier the a side fill | |
Buck Member
Buck Member
| Subject: Re: 82 Mudskee January 20th 2019, 8:43 pm | |
| so i fixed it haven't come out yet. win win | |
Buck Member
| Subject: Re: 82 Mudskee January 20th 2019, 8:49 pm | |
| I'm up in the Air with this tractor, i don't like the frame on it and the front has to be redone. i have it up for sale but really no bites only crappy trades. I might just strip it keep the engine and that sweet heavy duty transaxle | |
| Subject: Re: 82 Mudskee January 21st 2019, 11:13 am | |
| Yeah that's the thing with these. You've got a great trans and a motor. The rest of the tractor is thin stamped parts. Not very appealing. I would just part it out. | |
Age : 21 Join date : 2016-10-29 Points : 6627 Posts : 3643 Location : Lewisburg, KY
| Subject: Re: 82 Mudskee January 21st 2019, 9:29 pm | |
| Just coming across this thread, that's a nice tractor you got there. At least engine and trans wise. If you do part it out, you should keep that cool hood and put it on a craftsman or something. That could be cool. | |
Buck Member
| Subject: Re: 82 Mudskee January 21st 2019, 10:16 pm | |
| @Crazy_Carl @RichieRichOverdrive Y i think that's the plan, its hard to sell tractors here on the east coast of Canada, i have a guy wanting to trade a 196cc mini bike for it but i really don't need it. i rather sell it and use the money for parts or another 76 sears 16hp suburban | |
| 82 Mudskee | |
