| MTD off-road romper build. | |
+66MightyRaze ranch king pro 08 Axelsol89 CraftsmanQuad19 mowerheadder STUNTMAN JON Rockinator prancstaman MatthewD WilliesBuilds 98svtcobra MurrayMayhem jack9102 802 Customs untrusty huskee redlinemotorsportts Carshowkid rarbaugh07 mr.modified ZSmachines Deluxe66 Jerbear0612 Moose kawasaki220 Angchor B440 jamcco Craftsman1998 breadtrk camomanusa mrkadage MoWheeler Lawren Wimberly mzeng100 TheBeal T-Dub13 richie thomas GenevaCustoms muddstir 1997 Murray TroyBilt Pony Stretch44875 willis923 cumminsbayou crazykid1994 Creepycrawler k2500life xxXMowerdudeXxx genegillis5 TheRainbowBoxer Jamus LAWN MOWER MUDDER MowBandit 1993-Sierra-Z71 craftsmancole Doc Sprocket motorizedeverything flamudmower Murray modder Chopperhed Thunderdivine Ddwannabe mudmonkey06 Ariens YT11 Doug truckin42 70 posters |
| Subject: Re: MTD off-road romper build. November 12th 2014, 7:01 pm | |
| More stuff! All steering components. Decided i was going to mount a steering "box" on the axle, so this is what i got. Ariens auger box, 10:1 ratio, witch is pretty much perfect. Remember, full pitman arm motion is only about 50-60 degrees, so that about 3-3.5 turns of the shaft to move the pitman arm that much. U joints and keyed slider shaft from a 90's ford. This is how its gunna mount to the axle, (center) U-joints to the 3/4" shaft and pitman arm on the 1 shaft. Gearbox is oil filled, and 3/4" imput shaft and 1" output. | |
Carshowkid Member
Age : 24 Join date : 2014-07-22 Points : 3965 Posts : 347 Location : Downers Grove Illinois
Age : 23 Join date : 2013-04-08 Points : 5003 Posts : 913 Location : Central Pa
| Subject: Re: MTD off-road romper build. November 12th 2014, 7:22 pm | |
| Looks good Red! That steering should be bulletproof when finished! Are you thinking about doing two tie rods to the spindles? Sort of like gokart steering, but with a box instead of direct steering? | |
Age : 27 Join date : 2013-03-18 Points : 7277 Posts : 3131 Location : raleigh nc
| Subject: Re: MTD off-road romper build. November 12th 2014, 7:50 pm | |
| - LAWN MOWER MUDDER wrote:
- Looks good Red! That steering should be bulletproof when finished! Are you thinking about doing two tie rods to the spindles? Sort of like gokart steering, but with a box instead of direct steering?
Might as well draw up. Not to scale, and the pitman arm will be more straight, just popping it out there so you can see it, i plan on the push rod to be more in a straight line too. | |
rarbaugh07 Member
Age : 35 Join date : 2014-01-22 Points : 3871 Posts : 117 Location : Logan, iowa
| Subject: Re: MTD off-road romper build. November 12th 2014, 10:23 pm | |
| Love the g-box redline its perfect. How you going to route the steering shaft around the engine?
| Subject: Re: MTD off-road romper build. November 13th 2014, 6:41 am | |
| - rarbaugh07 wrote:
- Love the g-box redline its perfect. How you going to route the steering shaft around the engine?
Probably down through the frame and along the bottom of the chassis. | |
| Subject: Re: MTD off-road romper build. November 13th 2014, 6:48 am | |
Probably down through the frame and along the bottom of the chassis. What Lmm said, it will drop thru the frame where the original colum is right now. I'll have to move the mono link point where it mounts to the frame behind the joint. | |
Thunderdivine Veteran Member
Join date : 2012-12-21 Points : 6337 Posts : 2101 Location : Norway, Europe
Carshowkid Member
| Subject: Re: MTD off-road romper build. November 13th 2014, 8:39 pm | |
| So i did a few things. Tore the leafs and mounts off the frame. Mounting bars are off also. Mocked up front axle. beam is about 2" wider and the center disk of the rims stick out more too, but the 10" rims i have have a great offset to them that i will use to my advantage. The ride height in the front will be taller due to needing up and down travel and also the beam is placed higher on the spindles. I thought about moving the beam down the spindle "tubes" but its already welded perfect, and the steering box needs something to mount to up high. Stock: New: Now the offical ride height. my friend is getting me 23" swamp foxes for 10"x7" rims i got. So that should take up the rear fender space. Wheel base about 2" longer, 2" of liftin the rear, and roughly 3" lift in the front. Trying to stance out the rear to match the front without putting a ton of stress on the 820. Rear tires about 3" wider then original position. Measured out where the 21" will be up front on the axle. Looks like a lot of motion, more then i expected, good. I know it isnt much to look at, but bare with me, a few magic tricks with the welder should get it to the new state. | |
rarbaugh07 Member
| Subject: Re: MTD off-road romper build. November 13th 2014, 10:50 pm | |
| - rarbaugh07 wrote:
- Looks like a super tough stance. Excited to see your suspension setup.
Thanks, it seems pretty tall, but it's only lifted a little. Oh well, should mount bigger rocks. | |
rarbaugh07 Member
| Subject: Re: MTD off-road romper build. November 13th 2014, 11:19 pm | |
| Ya but your center of gravity is still low and having good shocks to keep you from bouncing you over in a tipsy situation. | |
jamcco Member
Age : 24 Join date : 2014-01-04 Points : 4010 Posts : 226 Location : New Hampshire
| Subject: Re: MTD off-road romper build. November 14th 2014, 4:30 pm | |
| - jamcco wrote:
- What do you think you'll get for flex?....
Im thinking as much as i want, but i dont want to much. if i have like 45 degrees of front axle flex that means the rear end can tilt 45 degrees and the front stay flat.... AKA, the thing tips over. It will have limit straps. | |
Doc Sprocket Site VIP
Age : 51 Join date : 2013-04-21 Points : 7112 Posts : 2914 Location : Ontario Canada
| Subject: Re: MTD off-road romper build. November 14th 2014, 7:34 pm | |
I'm glad you recognize that. Many people get nutty over front axle articulation ("flex"), and completely lose sight of this. Function over form, folks! | |
| Subject: Re: MTD off-road romper build. November 14th 2014, 7:58 pm | |
| - Doc Sprocket wrote:
I'm glad you recognize that. Many people get nutty over front axle articulation ("flex"), and completely lose sight of this. Function over form, folks! Thanks, All i want a is a better approach angle, little more flex, a super solid setup, and no steering lag. At school i used the ol metal lathe and turned some 1" to 7/8" to make misalignment spacers. The mono link ball joint is a 3 point hitch deal with a 7/8" hole. Misalignment spacers are suppose to covert a big hole to a smaller bolt hole and add more flex ability angles. Call me crazy, biut i looked at mine today and that looks like a good amount of axle flex. so i think all i need to do is drill a hole through the hole thing for a bolt, and i dont have to notch anything for more degrees. I dont know what degree it is now, but if that was my axle, that looks like a really good amount. | |
Carshowkid Member
| Subject: Re: MTD off-road romper build. November 14th 2014, 8:17 pm | |
| An interesting side effect to the worm gear steering, is you will have ZERO feedback thru the steering wheel. Good for hitting obstacles and NOT breaking thumbs... | |
jamcco Member
| Subject: Re: MTD off-road romper build. November 15th 2014, 11:20 am | |
I'm glad you recognize that. Many people get nutty over front axle articulation ("flex"), and completely lose sight of this. Function over form, folks! Nice, Articulation is nice to have, but too much of it is just a waste when it comes to being a practical machine...Looking forward to seeing this done. | |
Carshowkid Member
| Subject: Re: MTD off-road romper build. November 16th 2014, 6:42 am | |
| - Carshowkid wrote:
- Is that going to hold the entire axle?
Yep. No problem. Sweet welds, Red! | |
willis923 Veteran Member
Age : 27 Join date : 2013-04-10 Points : 5555 Posts : 1408 Location : Galway NY
| Subject: Re: MTD off-road romper build. November 16th 2014, 11:19 am | |
| #WeldPorn. youre doing great with that handler 140. too bad MTD will still be jenk. | |
| Subject: Re: MTD off-road romper build. November 16th 2014, 5:10 pm | |
| What welder did you use for that thick metal? Looks good. - and show us a plan of this secret suspension thingy, kinda looks like what i would build if i had the room for a mudder. | |
