| | Overdriving the output of a Hydro? Has anyone did it and how long did it last? | |
TheEquineFencer Member
Join date : 2013-02-19 Points : 4212 Posts : 90 Location : Farmville,NC, USA
| Subject: Overdriving the output of a Hydro? Has anyone did it and how long did it last? February 28th 2017, 10:01 pm | |
| I searched the forum and found this same question, but not an answer. I've got a 26HP VT BS in a 54 inch Husqvarna with a hydro. I'd like to build an ATU for the G/F to use around the farm but faster than a normal mower speed. I was thinking about building a frame with the hydro driving another axle behind the hydro with the second axle "split at the center" like a differential. I'd have two chains, one on each side to each driven side of the rear axle. Then when I wanted to, I could either pin/bolt them together to lock the rear axle. I'd probably shoot for a 3:1 or 4:1 OD ration. I'm open to ideas? | |
Age : 21 Join date : 2016-10-29 Points : 6598 Posts : 3626 Location : Lewisburg, KY
| Subject: Re: Overdriving the output of a Hydro? Has anyone did it and how long did it last? March 1st 2017, 5:16 pm | |
| Redneckcomputergeak (on youtube) set up his hydro mudder like that, except he used a straight axle in the back to lock the differential for more traction. People have set them up with two axles like you suggested also, but I think it's nicer to have a locked diff. As to longevity, I'm not sure. It certainly helps that you keep the transaxle clean to keep it cool, these hydros will burn up if they are caked in mud and overheat. It would certainly be cool to see someone else do it! | |
| | | AllisKidD21 Moderator
| Subject: Re: Overdriving the output of a Hydro? Has anyone did it and how long did it last? March 2nd 2017, 10:42 am | |
| Adding on to what Richie said about cooling, one could always build a sort of blower shroud for the hydro trans. They usually have a fan on the input shaft meant to blow cool air into the cooling fins, and if you built a shroud to go around the fan and the cooling fins (like an air cooled engine) it would keep dirt and Mud out and keep cool air in. It'd be pretty neat to see someone do that. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| | | | biggasmowers Veteran Member
Age : 23 Join date : 2016-12-30 Points : 4721 Posts : 1944 Location : Kansas
| | | | Sponsored content
| Who is online? | In total there are 27 users online :: 0 Registered, 0 Hidden and 27 Guests
