| | Newbie - Doug from Poland, NY | |
doin1964 New Member
Age : 59 Join date : 2021-06-15 Points : 1060 Posts : 1 Location : Poland, ny
| Subject: Newbie - Doug from Poland, NY June 16th 2021, 2:29 am | |
| Howdy, I just recently discovered that mud mowers were a thing and I am currently searching for my first project! I have learned enough to avoid buying a hydrostatic or shaft drive or MTD vary-drive type machine, but beyond that I will be depending on my own mechanical abilities and this forum for answers to questions I cannot answer!
I looked at a couple Simplicity mowers today and they had Tracto-static tranny's which appeared to be similar to the MTD Vary-drive set-up, with funky pulleys in the middle. So, I decided against this model.
Thanks in advance for your help . . . I am excited to get started.
Doug Poland, NY (population 451) | |
| | | Rustbucket Garage Veteran Member
Join date : 2021-01-15 Points : 2637 Posts : 1294 Location : Upstate New York
| | | | MightyRaze Administrator
Age : 49 Join date : 2016-09-06 Points : 15086 Posts : 10652 Location : Oklahoma
| Subject: Re: Newbie - Doug from Poland, NY June 16th 2021, 10:32 am | |
| Yeah shaft drives aren't bad. The White in my profile pic is shaft driven and I don't mud too hard, and I max out at 8 miles per hour, but I get zero belt slip and I will (fingers crossed) probably never break a transaxle. You can change gear sets if you feel so inclined, but from the factory shaft drives are usually slightly faster than belt drives anyway. Just my 2c | |
Age : 23 Join date : 2016-04-12 Points : 5761 Posts : 2623 Location : Indiana
| Subject: Re: Newbie - Doug from Poland, NY June 16th 2021, 5:24 pm | |
| Welcome!
As others have said, there are ways to speed up a shaft drive, they’re just usually more in depth. Different gear sets, taller tires, remove the Governor, those are the only three I can think of at the moment. Studebaker has a wicked old shaft driven cub cadet. That things a beast | |
| Subject: Re: Newbie - Doug from Poland, NY June 16th 2021, 6:34 pm | |
| X2 on Studabaker’s cub...Keizer is a tank and 1/2! Not trying to jack the thread though, carry on lol | |
| Who is online? | In total there are 17 users online :: 1 Registered, 0 Hidden and 16 Guests MightyRazeMost users ever online was 412 on January 7th 2023, 7:59 am |
