So I started this project a long time ago and was going to build a drift mower out of it, but then I decided not to build it, but I am attempting to enter it is this years build off with a few new ideas! It is a 1998 Murray Wide Body LT, all I have done to it so far is yank the engine off, flip the front end over to make it sit lower, remove everything that has to do with the deck, and put a locked up spicer in it. (The dirt bike is there to donate any random parts that I might need from it.)
I intend to put a artic cat 50cc 2 stroke in it, build custom independent front suspension, swap out the lawn mower rear end for the artic cats rear end, drop the seat down into the body, stretch the hood, fab custom steering, give it a fresh paint job (silver with white lightning bolts), make the body wider, make a hand brake, get a gas tank and make a spot for it, lower it to 4 inches off the ground in the front and 6 in the back, and that is all I can think of right now.
Nevadablue likes this post
Age : 49 Join date : 2016-09-06 Points : 15091 Posts : 10655 Location : Oklahoma
That's awesome, almost looks like it was designed to go there!
i dent even need to drill any holes i just drilled to holes it already had in the frame out some so the bolt would fit and now the wheel base still be the same to
Fastman Member
Age : 16 Join date : 2021-06-15 Points : 1254 Posts : 178 Location : Southern Oklahoma
I am pulling white lightning out of the build off their is no way it will be done on time the engine is trashed and I don't feel like spending 200$ for a new 2stroke artic cat engengine
