I see you still have your parking brake. Your setup is just like mine. Can you take a picture close-up of your brake system area? I have found that what I had was partially wrong and missing the parking brake.
I would really appreciate it. Your rig is turning out great!
BairleaFarm Member
Join date : 2023-10-11 Points : 385 Posts : 140 Location : Georgetown, KY
Hope you made out well in the rollover. Looks like you just need an engine and hood work? Dash and steering look good.
I think just a oil pan. The engine shut off but that could be because it ripped a fuel line loose. Dash tower is twisted a bit but steering looks and feels ok. Hood can be straightened but hood mounts are junk. Belt guide is junk. throttle cable and foot pedal are toast.
Ive got half a mind to to a 6" stretch in the rear and a front axle move forward in the front.
BairleaFarm Member
I cant get a picture with the current tires on but remind me when I pull it apart for rebuild.
Join date : 2021-01-15 Points : 2635 Posts : 1293 Location : Upstate New York
It looks like it’s just a bad block. Keep your eye on eBay, sometimes the bare block shows up cheap.
Adam’s small engine in Ohio has used blocks I believe, you can call him at (419) 685-2264. Bought some transmission guts from him before off eBay, worked out well.
Brianator Moderator
Age : 45 Join date : 2019-07-02 Points : 4347 Posts : 2383 Location : Ontario, Canada
Thats a good one mate, one I wouldn't have come off without a few cuss words! Hoods should be able to be bent back, engine is a... different story... looks to me like you effed that block up pretty good. Keep going at her, the carnage is sometimes all of the fun.
ranch king pro 08 Member
2023 Build-Off Top 3 Winner
Age : 15 Join date : 2023-06-01 Points : 667 Posts : 282 Location : East Texas
@BairleaFarm when I get home I will make sure it's all good and send you some pictures.if you decide you want it. I'll strip it down so shipping is cheaper
BairleaFarm Member
Picked up some parts. 2 520h a 418-8 snow plow and a brinley 10" plow. I need to make back 500 bucks quickly on this and need to do something thinking on what to sell and what to keep. Not keen on running a onan but guess I have 3 now lol.
Hillbilly mowers likes this post
PizzaKitty26 Member
Join date : 2023-01-24 Points : 642 Posts : 149 Location : ON
And so the addiction is full effect. Good luck. Next you know you have 10 tractors... widdle that down to 8, then family members give you a tractor. Then they get you another...and then you steel one away from another state because where you live they are 10x pricier..... Oh wait... Enough about me. LOL
Nah. If it doesn't run or isn't used I don't want it around here. I'm not one to hoard tractors that I'll never use just to try to fill a void in my heart. I hope this one sells quick. Clean 520h. The others will get converted or parted out.
