| Craftsman GT3000 "MUTT" Part I | |
+27Double W Cross Ranch Dave.MTD muckmudd biggasmowers Cambren Scott wenger Crazy_Carl richie thomas sadeoo7 prancstaman Lawren Wimberly ConfederaSears TheBeal tater195 Jymmyee Warren Evans 1997 Murray Thunderdivine Rockinator mr.modified MightyRaze TheGreenHornet CraftsmanQuad19 Murryman AllisKidD21 MatthewD Doug RichieRichOverdrive 31 posters |
| Subject: Re: Craftsman GT3000 "MUTT" Part I March 4th 2018, 12:30 pm | |
| Finally got a start on a go pro mount. Have all the pieces cut out, just gotta zap em together. Using a piece of 3/4" EMT for the main arm. Stripped the galvanize about 6" from both ends, hopefully I won't get zinc poisoning lol. | |
biggasmowers Veteran Member
Age : 23 Join date : 2016-12-30 Points : 4722 Posts : 1944 Location : Kansas
| Subject: Re: Craftsman GT3000 "MUTT" Part I March 4th 2018, 12:34 pm | |
| Meh I weld galvanised all the time, just keep your head out of the smoke plume and have good air flow. | |
Age : 49 Join date : 2016-09-06 Points : 15057 Posts : 10635 Location : Oklahoma
Age : 25 Join date : 2016-07-10 Points : 8379 Posts : 5190 Location : Ontario Canada
| Subject: Re: Craftsman GT3000 "MUTT" Part I March 4th 2018, 1:16 pm | |
| Yeah the zinc coating makes it difficult to weld, so I always grind it away as well. I work outside too so I haven't really been affected by the fumes or anything. I mean, I'm not getting any crazier, haha. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
Age : 21 Join date : 2016-10-29 Points : 6601 Posts : 3628 Location : Lewisburg, KY
| Subject: Re: Craftsman GT3000 "MUTT" Part I March 4th 2018, 1:18 pm | |
| Just welded it up and the only headache I have is from the spray paint lol. 'Pologies to the people on pc, it's gonna come up as a thumbnail lol. Just click on it to see full size. | |
| Subject: Re: Craftsman GT3000 "MUTT" Part I March 4th 2018, 1:23 pm | |
| Looks nice Rich. So where on the tractor is it gonna bolt on? "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: Craftsman GT3000 "MUTT" Part I March 4th 2018, 1:31 pm | |
| Bolts on top of the hitch plate bolt on thingy i made. I'll get a pic later when the paint cures and I bolt it on.
Also it seem I've lost track of my waterproof gopro case. Gotta find that lol | |
| Subject: Re: Craftsman GT3000 "MUTT" Part I March 4th 2018, 8:29 pm | |
| So this is how it ended up at first. Bolted on where the hitch plate originally bolted to the snapper frame. Ended up being too shaky, so I added a support that bolted to the other side of the hitch plate. Still kinda wobbles around a bit, but it's not too bad. I'm getting better at fabbing stuff with tubing lol. Gonna put a few of the test vids up on youtube. The echo through the frame from the trans is pretty brutal. I'll put some of my test vids up. | |
Crazy_Carl Veteran Member
Age : 35 Join date : 2017-10-30 Points : 5125 Posts : 2561 Location : Rochester, New York
| Subject: Re: Craftsman GT3000 "MUTT" Part I March 4th 2018, 8:32 pm | |
| Practice makes perfect when it comes to welding and fabrication. I'm looking forward to seeing the footage. | |
| Subject: Re: Craftsman GT3000 "MUTT" Part I March 4th 2018, 10:32 pm | |
| Video will be up in about an hour and a half. I had cut a slot in the side of this piece for whatever reason, I had it already cut and whatever but I can't remember what I was using it for. Anyways I'm gonna fill it in(or at least add a bridge at the top), should add some rigidity. Can't believe I didn't think to do that before lol. | |
| Subject: Re: Craftsman GT3000 "MUTT" Part I March 5th 2018, 7:32 am | |
| Aside from the mount bouncing up and down all the time, and the whine from the trans amplified through the frame and camera mount, yeah it was alright lol.
This morning it occurred to me that I still have some of the the 3M tape stick on mounts, I think this would be a perfect opportunity to use one of those. Should act as a sort of sonic dampener too. | |
| Subject: Re: Craftsman GT3000 "MUTT" Part I March 5th 2018, 7:35 am | |
| Not a bad idea. I could also mail you a couple of the old isolation mounts for Ol Red. You could use those to rubber shock mount the camera. I wonder if that would help with the noise too. | |
| Subject: Re: Craftsman GT3000 "MUTT" Part I March 5th 2018, 7:43 am | |
| I have a few rubber shock mounts, they're like 60 years old, but pretty much new(got em out of the old trade school, they were there when that school was built). Thought about using one of those, but the hole in the center isn't standard thread, it's somewhere around 5/16", but doesn't seem to be UNF or UNC. Could retap it to whatever, but I don't think the extra weight at the end of the pole would be worth it. | |
| Subject: Re: Craftsman GT3000 "MUTT" Part I March 5th 2018, 7:51 am | |
| You've got a point there. The extra weight might make it move more or maybe it will dampen vibration. If the the threads are close to 5/16, it's probably M8. | |
| Subject: Re: Craftsman GT3000 "MUTT" March 5th 2018, 8:18 am | |
| Dunno, like 3 and a half or 4 feet. Didn't take any measurements in the making of the thing, just did it pretty much from sharpie marks and a lot of checking and fitting, lol.
I don't know why both of my 820s have been so loud. Might be because I only put used 15w-40 in em? I know my input bearings aren't the greatest, but I'm not sure they'd be the problem. Maybe when I get some money I'll pick up a new bearing and some Lucas oil stabilizer or something. | |
Age : 23 Join date : 2016-04-12 Points : 5747 Posts : 2619 Location : Indiana
| Subject: Re: Craftsman GT3000 "MUTT" Part I March 5th 2018, 9:26 am | |
| Used oil? well it was designed for grease so i would think any oil would be a bonus but the thicker the better so the oil can get carried up the clusters to the imput shaft bearings , that might be why they are so loud. | |
| Subject: Re: Craftsman GT3000 "MUTT" Part I March 5th 2018, 10:26 am | |
| I was thinking it might be too thin for it. Maybe I'll shove some grease in there too next time I fill it lol | |
Age : 20 Join date : 2017-06-09 Points : 5284 Posts : 2640 Location : Literally Nowhere, Texas
| Subject: Re: Craftsman GT3000 "MUTT" Part I March 5th 2018, 5:09 pm | |
| Also put some Lucas Oil Transmission Fix in it, the stuff is awesome. Renews old oil and quiets the trans. It actually does renew the oil, too. I've put it in oil that looked like peanut butter, stirred it around, it changed colors and freed it up. | |
| Subject: Re: Craftsman GT3000 "MUTT" Part I March 5th 2018, 7:02 pm | |
| I'll have to look into that. Hit the top of the mount with some emery cloth and stuck the mount on. Tape seems skookum enough. Took a little bit of that whine out of the video I think. Not much though. However the mount still vibrates way too much, even after I filled in the top of that crack with the MIG(I have more experience than I'd like to admit to with filling holes with a welder). Gave myself permission to another piece of EMT. This better be the mount to end all mounts when I'm done. | |
