| Craftsman GT3000 "MUTT" Part I | |
+27Double W Cross Ranch Dave.MTD muckmudd biggasmowers Cambren Scott wenger Crazy_Carl richie thomas sadeoo7 prancstaman Lawren Wimberly ConfederaSears TheBeal tater195 Jymmyee Warren Evans 1997 Murray Thunderdivine Rockinator mr.modified MightyRaze TheGreenHornet CraftsmanQuad19 Murryman AllisKidD21 MatthewD Doug RichieRichOverdrive 31 posters |
Age : 21 Join date : 2016-10-29 Points : 6598 Posts : 3626 Location : Lewisburg, KY
Crazy_Carl Veteran Member
| Subject: Re: Craftsman GT3000 "MUTT" Part I March 13th 2018, 6:27 pm | |
| Yeah not much time in a class to get in some real machine time. Both of the machine shops where I worked we did 10 hour days, and we were always running a machine or two. | |
| Subject: Re: Craftsman GT3000 "MUTT" Part I March 13th 2018, 8:38 pm | |
| Yeah we need like 2 hour classes lol. I was gonna have machine tool for both electives next year, but I'm going for a machine tool class and band lol. | |
muckmudd Established Member
Age : 21 Join date : 2017-07-11 Points : 3352 Posts : 825 Location : In the shop
| Subject: Re: Craftsman GT3000 "MUTT" Part I March 14th 2018, 12:59 am | |
| I have 1 hour blocks every day and on fridays I get a 1 and a half hour block in the metalwork room, pretty nice to just be able to bring things that need to be machined to school. | |
| Subject: Re: Craftsman GT3000 "MUTT" Part I March 15th 2018, 11:02 pm | |
| Yeah, it's sweet. Took her for a little ride today after school. Trans noise has gotten a lot worse. Think I'll put her away til i can do a sort of rebuild. Oh, and the brakes need a new return spring, I may or may not have wrapped a tree around my wheel and it kinda knocked the loose one that's on there off. Luckily I found it lol. They could use adjusted too. | |
| Subject: Re: Craftsman GT3000 "MUTT" Part I March 15th 2018, 11:09 pm | |
| She looks pretty awesome, haha. Sucks about the trans noise, kinda sounds like maybe a pinion shaft bearing to me. If you take the belt off is there any play in the trans pulley? "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: Craftsman GT3000 "MUTT" Part I March 15th 2018, 11:17 pm | |
| Oh yeah. You can feel the pinion gear isn't meshed perfectly when you turn it too. Unfortunately I noticed that after I put the thing together. | |
| Subject: Re: Craftsman GT3000 "MUTT" Part I March 15th 2018, 11:20 pm | |
| Ah, well that sucks. At least you know that's probably what the noise is. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
Age : 22 Join date : 2018-02-27 Points : 3637 Posts : 1299
| Subject: Re: Craftsman GT3000 "MUTT" Part I March 20th 2018, 5:35 pm | |
| From the beginning to now, out of a stock craftsman lawn tractor originated an really nice Offroad Mud Mower that can handle abusing really good. Like it! | |
| Subject: Re: Craftsman GT3000 "MUTT" Part I March 23rd 2018, 11:28 pm | |
| Almost done with the machine work for the new steering shaft, cut a thread on the end to have instead of a stupid snapring. Pretty good for my first threading job. All I really have left to do is drilling a 1/8" hole for the roll pin that holds the pinion gear on. | |
TheBeal Veteran Member
Age : 29 Join date : 2013-06-06 Points : 5504 Posts : 1398 Location : Central PA
Age : 20 Join date : 2017-06-09 Points : 5283 Posts : 2640 Location : Literally Nowhere, Texas
| Subject: Re: Craftsman GT3000 "MUTT" Part I March 24th 2018, 11:05 am | |
| Thanks everybody. - TheBeal wrote:
- Lookin good Rich. Did you cut the threads with a bit or use a die?
With a 60* threading tool lol. | |
| Subject: Re: Craftsman GT3000 "MUTT" Part I March 24th 2018, 11:51 pm | |
| - MightyRaze wrote:
- WOW that looks factory!
Did you just cut till the nut threaded on? Or did you math it all out and measure the threads using the wires? | |
| Subject: Re: Craftsman GT3000 "MUTT" Part I March 25th 2018, 12:00 am | |
| Looks sorta meh. Surface finish across the whole thing is sorta trashy.
I cut down to around .081", which is that the depth for 16TPI is supposed to be, then I kept taking little cuts til i had about a class 1 fit. | |
| Subject: Re: Craftsman GT3000 "MUTT" Part I March 25th 2018, 1:14 am | |
I'd have to agree on that for sure. Nice work Rich! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: Craftsman GT3000 "MUTT" Part I March 25th 2018, 10:18 am | |
- Yeah, I did this all with carbide.
What? You didnt have to grind a HSS bit to do it? Cheater. | |
| Subject: Re: Craftsman GT3000 "MUTT" Part I March 25th 2018, 10:21 am | |
| Actually I had to screw around with an insert and regrind the threading tool lol, HSS isn't hardly even used out in the real world anymore! | |
