| [Complete] MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry] | |
+13AllisKidD21 CraftsmanQuad19 Camdg2010 MatthewD RichieRichOverdrive muckmudd Crazy_Carl mr.modified Dave 007 Double W Cross Ranch MightyRaze Doug mrshaft696 17 posters |
mrshaft696 Established Member
Join date : 2016-07-10 Points : 3851 Posts : 870 Location : Phillydelphia
| Subject: [Complete] MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry] February 1st 2018, 8:37 pm | |
| Its on now...project is ready to roll...... This is what the tractor started as..... Goals of the project are to stretch the tractor about 2ft, in the middle & add a little bit in the rear to mount a class II hitch. The red sears trailer is going to become the dump bed. Going to run 25" tires in the rear & 22's in the front. Discarding all the craftsman sheet metal in favor of a simplicity hood, will fabricate the running boards & fenders. There are dozens of other modifications that have to happen with the linkage & belts etc. Running a hydro rear for now for the control & slow crawl, I like to be able to walk with the tractor when we work on the property. I bought the tractor not running for 33 bucks & have another donor frame for the stretch.... -Approved by Doug, 2/1/2018
Last edited by mrshaft696 on February 1st 2018, 9:10 pm; edited 1 time in total | |
Doug Site Owner
Age : 28 Join date : 2012-12-24 Points : 7561 Posts : 3035 Location : Lebanon County, PA
Age : 49 Join date : 2016-09-06 Points : 15057 Posts : 10635 Location : Oklahoma
Age : 20 Join date : 2017-06-09 Points : 5284 Posts : 2640 Location : Literally Nowhere, Texas
| Subject: Re: [Complete] MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry] February 4th 2018, 8:49 pm | |
| Did a little bit of work this weekend... I got my belt mocked up and im afraid because of the length of it, I will need some idler pulleys just to keep the belt from being floppy in the middle. I want to get the pulleys in place before I weld the frame back together because there is no going back after that... | |
Dave 007 Member
2017 Build-Off Top 3 Winner
Age : 60 Join date : 2017-02-02 Points : 2773 Posts : 115 Location : Australia
| Subject: Re: [Complete] MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry] April 30th 2018, 7:24 am | |
| Finally got my donor frame cleaned up & measured out for what section I'm going to use, then ran out of time. I was having a hard time keeping the frame square with just the angle iron holding the two halves, so I think having the frame section cut and tacked in place with force the angle iron to be straight. | |
Age : 34 Join date : 2013-11-02 Points : 6955 Posts : 2906 Location : New Jersey USA
Crazy_Carl Veteran Member
Age : 35 Join date : 2017-10-30 Points : 5125 Posts : 2561 Location : Rochester, New York
muckmudd Established Member
Age : 21 Join date : 2017-07-11 Points : 3353 Posts : 825 Location : In the shop
| Subject: Re: [Complete] MrShaft696 Stretched CraftsmanPlicity [2018 Build-Off Entry] June 16th 2018, 10:52 pm | |
| - muckmudd wrote:
- Get an old rim and either drill holes in it and slide bolts through or weld on some threaded rod.
Right but i need the keyed center section, the best I can think of is cutting the 8" rim and welding inside of the 12" rim..... I guess it is possible to find a 5 lug hub off of a cub cadet or wheel horse maybe>? Weld it on or use a set screw? | |
Age : 21 Join date : 2016-10-29 Points : 6601 Posts : 3628 Location : Lewisburg, KY
