| 100$ Dation 16HP MTD 990 "Mud Train" | |
+10darkside0914 RichieRichOverdrive CraftsmanQuad19 Double W Cross Ranch MightyRaze MatthewD biggasmowers AllisKidD21 TheBeal Crazy_Carl 14 posters |
Crazy_Carl Veteran Member
| Subject: Re: 100$ Dation 16HP MTD 990 "Mud Train" May 1st 2018, 8:59 pm | |
| Is it possible to put that coil on backwards? The timing is way too advanced. 75 PSI seems kinda low to me for compression, but something is going on if it tripled. | |
RockeyDA Established Member
Age : 29 Join date : 2017-10-15 Points : 3051 Posts : 639 Location : Bellefonte PA
| Subject: Re: 100$ Dation 16HP MTD 990 "Mud Train" May 2nd 2018, 5:00 am | |
| when the thing ran good it had only 25psi. and i did put the could on backwards, it did not spark the correct way. something i did not mention here or in the video is last time it ran when had weak spark at one point it made a harsh bang, then it kept making these harsh rattly bangs till it stalled out, and it never started again. i hoped it was ignition knock since i had weak spark. | |
| Subject: Re: 100$ Dation 16HP MTD 990 "Mud Train" May 14th 2018, 3:23 pm | |
| well, still have not got the drive shaft off, snapped my last dremmel bit seeing if i could get it in there to make a slit for a flat head. | |
| Subject: Re: 100$ Dation 16HP MTD 990 "Mud Train" August 11th 2018, 1:50 pm | |
| Now that I've watched a couple of these videos I'd say there's an ignition problem here causing it to fire backwards, 75 PSI of compression is nowhere near high enough to casue those kind of issues. Also it happened as soon as you put that new coil on, which seems like a pretty good indication to me that the issue is spark timing related. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
Age : 21 Join date : 2016-10-29 Points : 6598 Posts : 3626 Location : Lewisburg, KY
| Subject: Re: 100$ Dation 16HP MTD 990 "Mud Train" August 11th 2018, 3:48 pm | |
| Have you checked out the flywheel key? Really sounds like it sheared. Is it hydrolocked? I doubt the compression release failed.
You have allen wrenches don't you? | |
| Subject: Re: 100$ Dation 16HP MTD 990 "Mud Train" August 12th 2018, 12:33 pm | |
- Have you checked out the flywheel key? Really sounds like it sheared. Is it hydrolocked? I doubt the compression release failed.
You have allen wrenches don't you? how do you explain the trippling of compression? and yes i do, i snapped one off in the other side of that pully, i hammerd it in and used a breaker bar in it, actualy it might have been a start bit. | |
| Subject: Re: 100$ Dation 16HP MTD 990 "Mud Train" August 12th 2018, 12:45 pm | |
| The compression increase could have been caused by the rings seating a bit better due to running a few different times, or something like that. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: 100$ Dation 16HP MTD 990 "Mud Train" August 12th 2018, 12:51 pm | |
| i can tell you this thing firing the wrong way happend before i changed the magnete, i was hoping the magneto was the problem is the spark was really weak from it the new one proved much much better spark. also what keystock are you talking about? i dont see any evidence they fly whel has moved from its position with the shaft. | |
| Subject: Re: 100$ Dation 16HP MTD 990 "Mud Train" August 12th 2018, 12:52 pm | |
- I really think its the flywheel key causing most of this.
Are you sure it's not hydrolocked? its an updraft carb, im not flooding the motor with liquid gas. | |
| Subject: Re: 100$ Dation 16HP MTD 990 "Mud Train" August 12th 2018, 2:30 pm | |
| Looks like that shaft is the flywheel nut? That small plate helps lock it in place via the hex head on the shaft nut. To check the key being sheered, you would have to remove the little plate and that shaft. (should unscrew with a deep well and impact). Then see if the keyway lines up. | |
| Subject: Re: 100$ Dation 16HP MTD 990 "Mud Train" August 12th 2018, 4:31 pm | |
| - MightyRaze wrote:
- Looks like that shaft is the flywheel nut? That small plate helps lock it in place via the hex head on the shaft nut. To check the key being sheered, you would have to remove the little plate and that shaft. (should unscrew with a deep well and impact). Then see if the keyway lines up.
deep well impact? so i can just use an adjustable wrench right? becase i dont got any sockets that wold fit that for an impact drill. | |
Age : 23 Join date : 2016-04-12 Points : 5745 Posts : 2618 Location : Indiana
| Subject: Re: 100$ Dation 16HP MTD 990 "Mud Train" August 12th 2018, 6:13 pm | |
| Yikes, adjustable wrench sounds like strip the head city? Also if you do have a big wrench, you may be able to put rope down the spark plug to keep it from turning all the way over. wedging something in the flywheel fans could break them off. | |
| Subject: Re: 100$ Dation 16HP MTD 990 "Mud Train" August 30th 2018, 7:05 pm | |
| well, i could not get the fly wheel off, i also took the carb off and held my hand over the intake and check for sucsion, i got a little then alot of blow, way more blow than suck. im back on thinking my timing is off without a doubt. | |
| Subject: Re: 100$ Dation 16HP MTD 990 "Mud Train" October 19th 2018, 1:56 pm | |
| I GOT IT! I GOT IT! I GOT IT! I GOT IT! I GOT IT! that thing ended up being a metalic swis roll of metaly metal. video if its romval might be out tonight. im about to head back out and see if i can fix the motor without new parts. if i can, i will and im keeping it. if i cant its still free for any one who wants it and ile stick with that 12hp that needs rings. | |
| Subject: Re: 100$ Dation 16HP MTD 990 "Mud Train" October 19th 2018, 4:01 pm | |
| If you bypassed the condenser and breaker points there won't be any timing adjustment anymore. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
