Figured I would post this beauty on here, I think it is bout finished, just need ideas on how to make the hood look good. Also I would like to put a bull bar on it, and need ideas on how to do that to. Thanks
BairleaFarm Member
Join date : 2023-10-11 Points : 375 Posts : 140 Location : Georgetown, KY
If you can get your hands on an old tarp shed frame and some grating you could do something like @diddie did and even skin it with the hood. Looks good IMO.
Got a tire upgrade, much better than the dirt track tires that were on it. I found a pair of 5 bolt carlsie all trails that someone threw out and welded them on to a pair of old 3/4 rims. Now I need a pair of fronts! Excuse my crappy welds. Had to swap this rim out for a different one that I had in the tire pile.
PizzaKitty26 Member
Join date : 2023-01-24 Points : 632 Posts : 149 Location : ON
Took this guy mudding, here's the after math. Need better rear belt guards apparently. Also a bit of carnage from taking a corner to fast on my tracked go kart. Tracks didn't break thankfully, just had to reseat them.
Hey pizzakitty26 if u don't mind me asking are u running fnrs transaxles.
No problem, forgot to tell you'll about this machine , I am running a peerless 6 speed, don't know the model (it's kind of covered in mud right now, can't read it.) It goes probally about 60 kmh, I have a briggs 18 horse oppy with straight pipes on it, on craftsmans you can literally undo 4 bolts and the muffler drops off, leaving the pipes on. Stock steering, 8 inch front pulley, 3 inch back. @mightyraze I have no humanly idea as to how those seat springs are clean.
PizzaKitty26 Member
So... It ate a belt on Saturday, I figured out it is because the transaxle that is in it is not stock, so the rear driven pulley is an inch or two higher than the front, so I need to lift the transaxle.
PizzaKitty26 Member
Lifted the transaxle, that was easier than expected, I just slid the mounts down an inch, there happened to be a second set of holes there Got a new belt, turns out peavy mart doesn't have a belt bigger than 96'', so I bought that and put a smaller pulley on the front, redid the belt guards, and now she should be ready. Also, the steering linkage that connects the two spindles was bent on a 20 degree angle, so it had a lot of tow out so I reinforced that with another piece of metal after bending it straight again. I also put the tires that used to be on the back on the front and it has way less understeer now.
Just a little update, I have decide this is more of a trail mower, it sucks in the mud, just kind of slings it everywere and it would need a locked transaxle, which I don't care to do. Other than that, it works pretty good, I just need to hook up the throttle cable to the gas pedal I fabbed, and some small wiring issues. If anyone can think of a good name for this that would be nice. Even with the smaller front pulley, it still goes about 40. I took it out for a couple rides around the field and took it mudding in a swamp area (I know, that was a pretty terrible idea, it took a come-along, a tie strap, and a 300 pound Bolens tractor to get it out of that) and it still hasn't dropped the belt so I am super happy about that.
Brianator Moderator
Age : 45 Join date : 2019-07-02 Points : 4337 Posts : 2383 Location : Ontario, Canada
Your rear tires are holding you back in the mud for sure but there is all kinds of different mud too! Lol. I find that JUST enough wheel speed to clear the treads gets me through mud better than alot of wheel speed above that point but for sure a locked rear is great in mud! Nothing in regards to a name is jumping out at me yet but I'll let you know if anything does!
they are from Toronto, they always stay clean but don't actually do anything
Those are about the same seat springs I have on mutt, can confirm that they dont do much In fact this tractor has the same frame as mutt, could nearly be the same tractor with a few years worth of mods
Part of the issue is I don't have much in the way of tread in the middle, only on the side which is better for trails anyways.
