| Craftsman GT3000 "MUTT" Part I | |
+27Double W Cross Ranch Dave.MTD muckmudd biggasmowers Cambren Scott wenger Crazy_Carl richie thomas sadeoo7 prancstaman Lawren Wimberly ConfederaSears TheBeal tater195 Jymmyee Warren Evans 1997 Murray Thunderdivine Rockinator mr.modified MightyRaze TheGreenHornet CraftsmanQuad19 Murryman AllisKidD21 MatthewD Doug RichieRichOverdrive 31 posters |
Age : 23 Join date : 2016-04-12 Points : 5746 Posts : 2619 Location : Indiana
biggasmowers Veteran Member
Age : 23 Join date : 2016-12-30 Points : 4721 Posts : 1944 Location : Kansas
Age : 21 Join date : 2016-10-29 Points : 6600 Posts : 3628 Location : Lewisburg, KY
| Subject: Re: Craftsman GT3000 "MUTT" Part I Thu Apr 19, 2018 7:36 am | |
| My bearings were shot, the top one wouldn't move and the bottom needle bearing fell apart . Are they just abfewbbucks? | |
Age : 22 Join date : 2018-02-27 Points : 3637 Posts : 1299
| Subject: Re: Craftsman GT3000 "MUTT" Part I Thu Apr 19, 2018 10:36 pm | |
| Looks great Rich! Should work great. Decide on a PCV setup yet? "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: Craftsman GT3000 "MUTT" Part I Thu Apr 19, 2018 11:02 pm | |
| I wish I had some of the capabilities you have. Great resource. Better get your fabbing items done before end of school! | |
| Subject: Re: Craftsman GT3000 "MUTT" Part I Fri Apr 20, 2018 7:07 am | |
| for what you want to use this adapter that attaches the hose? new Air Filter Snorkel? If it will be the adapter between the air filter and the carb, do'nt forget to add a fitting for the crankcase ventilation | |
Crazy_Carl Veteran Member
| Subject: Re: Craftsman GT3000 "MUTT" Part I Fri Apr 20, 2018 5:49 pm | |
| Since this is for an Oppy I would bore it out bigger to increase air flow. Cool looking part though. The thinner wall will make it tricky to tap for the fitting for the PCV valve. Do you know someone that can tig on a threaded bung on there? | |
| Subject: Re: Craftsman GT3000 "MUTT" Part I Fri Apr 20, 2018 6:03 pm | |
| I could have somebody in welding do it. Not a big deal though, really. And if you look down the bore of the carb, it gets down to like 3/4", so i think 1" will be alright. "Mutt by Powerwheels" -Allis and Carl 2018 | |
| Subject: Re: Craftsman GT3000 "MUTT" Part I Fri Apr 20, 2018 6:08 pm | |
| Hehehe, it's true I'm telling ya! Also I agree about the bore, the actual venturi of the carb is much smaller that 1", so I bet that setup will work fine. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: Craftsman GT3000 "MUTT" Part I Fri Apr 20, 2018 6:22 pm | |
| Oh I see now that 1" should be fine. It's funny with so much distance between the rear tires and the fenders, it looks like you have 4-6" of rear suspension travel in there now. | |
| Subject: Re: Craftsman GT3000 "MUTT" Part I Sat Apr 21, 2018 10:48 am | |
| Hahaha. Little tiny Ags in the rear, and then put the tiny knobbies on the front. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
Age : 20 Join date : 2017-06-09 Points : 5283 Posts : 2640 Location : Literally Nowhere, Texas
| Subject: Re: Craftsman GT3000 "MUTT" Part I Sun Apr 22, 2018 7:02 am | |
| that’s a classic video “Mom I’m fine!” lol
Anyway I would drop the bowl on the carburetor to make sure there’s no oil in it and put in a new set of plugs since that set is fouled from all the oil. | |
| Subject: Re: Craftsman GT3000 "MUTT" Part I Sun Apr 22, 2018 8:20 am | |
| - Crazy_Carl wrote:
- that’s a classic video “Mom I’m fine!” lol
Anyway I would drop the bowl on the carburetor to make sure there’s no oil in it and put in a new set of plugs since that set is fouled from all the oil. I'd just say screw it and send her, lol. Course I ain't the sharpest bulb in the drawer.... Nice roll Rich! I still say you need a haircut. | |
