| | Mower update | |
Caddy_V3 Member
Age : 24 Join date : 2015-07-10 Points : 3320 Posts : 56 Location : Derry NH
| Subject: Mower update July 22nd 2017, 10:06 pm | |
| SO i've benn slowly working on my machine when i'm not distracted my mom's freaking VW Cabrio. So ive finaly goten a Spicer 6 speed to swap out my Peerless. I did the Fearless Carb mod. (note a older post i had kinda the same idea little over a year ago. I acquired brand new un-opened tire chains at good will by the pound (score). first thing, the new carb, i dont got a return line so if it's not runing it pisses gas like a SR-71. next the vinal tube is the pcv drain that i just felt like not hooking up to the intake. (cus screw the epa) here you can see the gas pedal the exsaust curently is just the old intake that is going to be the header. the rusty pease is a header off a brigs oposed that kinda fits. i had to cut a pace of the rear chassy plate to make the spicer fit. under neath i got a new dual pully set up that is tened with a 1/4 inch turn buckle. (2 2.5" pulleys if i rember right) tire chains (im too cheap for now to buy tiers) | |
Age : 21 Join date : 2016-10-29 Points : 6601 Posts : 3628 Location : Lewisburg, KY
| Subject: Re: Mower update July 23rd 2017, 1:47 am | |
| Looks good! You should cover that hole in the side of the blower shroud or you may have problems with overheating. I've just taped em off with some duct tape before. What pulley swap you running? | |
Age : 34 Join date : 2013-11-02 Points : 6955 Posts : 2906 Location : New Jersey USA
| Subject: Re: Mower update July 23rd 2017, 2:48 am | |
| Looking good, where'd you get that nifty carb? The aluminum exhaust/intake header is neat. I think someone had aluminum exhaust manifolds for drag cars or something in the 60's to save weight. I read about it but I don't remember all the details. Keep us updated! | |
Age : 57 Join date : 2013-12-21 Points : 4597 Posts : 744 Location : Salem Illinois
| Subject: Re: Mower update July 23rd 2017, 7:02 am | |
| - mr.modified wrote:
- Looking good, where'd you get that nifty carb? The aluminum exhaust/intake header is neat. I think someone had aluminum exhaust manifolds for drag cars or something in the 60's to save weight. I read about it but I don't remember all the details. Keep us updated!
The aluminum exhaust manifolds didn't catch on because they tended to melt in race application... spewing molten metal at spectators is strictly prohibited at nhra events in our case, relatively low rpm and low heat output makes it feasible, though AL does tend to crack when it gets hot | |
Age : 49 Join date : 2016-09-06 Points : 15057 Posts : 10635 Location : Oklahoma
| Subject: Re: Mower update July 23rd 2017, 10:24 am | |
| - Lawren Wimberly wrote:
The aluminum exhaust manifolds didn't catch on because they tended to melt in race application... spewing molten metal at spectators is strictly prohibited at nhra events Awe, who doesn't like molten aluminum slung at them? | |
| | | Caddy_V3 Member
| Subject: Re: Mower update July 23rd 2017, 7:13 pm | |
| So my pulley's are 3" in the front and 3" in the rear. Just got the car off E-Bay, nearly bolts up with little effort. Just to throw this out there, note the intake is plastic. Yes it is the intake so it dose not see the heat of the exhaust but it is bolted right to the head. | |
| Subject: Re: Mower update July 23rd 2017, 9:09 pm | |
| A lot of guys do like the 1:1 pulley ratio. With both yours being 3", you may have some belt slip. I hear a lot of two 5's or 6's. Something to keep in mind. | |
| | | | | Mower update | |
| Who is online? | In total there are 37 users online :: 1 Registered, 0 Hidden and 36 Guests ranch king pro 08Most users ever online was 412 on January 7th 2023, 7:59 am |
