| Craftsman Lt4000 mild off-roader | |
+5Crazy_Carl RichieRichOverdrive AllisKidD21 CraftsmanQuad19 muckmudd 9 posters |
muckmudd Established Member
| Subject: Re: Craftsman Lt4000 mild off-roader January 4th 2018, 9:17 pm | |
| I did a carb swap on the mower today. I put the carb that was on the mud mower on it because I know it works and I thought that it would solve the problem. Sure enough with my luck it didn't, so then I tried bypassing my safety switches by following what I did on the race mower. When I started it back up after that, It just turned over a bunch and didn't start. Now my stupid battery is dead because it doesn't charge well and only has enough juice for a few starts. Tomorrow I will try again when its not dark. | |
Age : 21 Join date : 2017-07-11 Points : 3353 Posts : 825 Location : In the shop
| Subject: Re: Craftsman Lt4000 mild off-roader January 6th 2018, 11:01 pm | |
| It runs so good now after a few days of work. Now I gotta lock it and swap tires because they leak pretty bad. | |
Age : 49 Join date : 2016-09-06 Points : 15057 Posts : 10635 Location : Oklahoma
| Subject: Re: Craftsman Lt4000 mild off-roader January 7th 2018, 4:05 pm | |
| - mightyraze wrote:
- Excellent Muckmudd. SO it was the carb? Glad you got it going good.
No, after swapping out the coil, carb and buying a new spark plug. i figured out it was just another faulty electrical system because I had recently deleted all the safety switches. | |
| Subject: Re: Craftsman Lt4000 mild off-roader January 7th 2018, 6:39 pm | |
| How would you know what it sounds like now? but yeah it sounds really good I just want it to idle a little slower.
| Subject: Re: Craftsman Lt4000 mild off-roader January 20th 2018, 7:00 pm | |
| Ropmed the old grey last weekend and this weekend for a little more than an hour. So fun going crazy on this thing even if it's stock. I need to lock this thing pretty bad and do a tire swap sometime. Today I got it stuck in the mud and all four tires were completely emerged. I also drove it into a creek and blew the bead right of the tire so I had to run home and steal the tire off the other craftsman. | |
Crazy_Carl Veteran Member
Age : 35 Join date : 2017-10-30 Points : 5125 Posts : 2561 Location : Rochester, New York
| Subject: Re: Craftsman Lt4000 mild off-roader January 21st 2018, 8:22 am | |
| If you're on a budget I'd just keep an eye out for some atv tires that will fit your rear rims. They look like 8" and you have plenty of clearance under those fenders for bigger tires. | |
| Subject: Re: Craftsman Lt4000 mild off-roader January 21st 2018, 2:38 pm | |
| No I haven't Mighty. But I don't see why they would. This mowers was fairly well maintained and the front wheel still had a bunch of grease when I took it off, Also, there is still the caps on so water can't get in as easy. But we will see when I lock the diff. | |
Age : 20 Join date : 2017-06-09 Points : 5284 Posts : 2640 Location : Literally Nowhere, Texas
| Subject: Re: Craftsman Lt4000 mild off-roader January 21st 2018, 4:02 pm | |
| That should do great, I love Craftsmans! You can mud them stock and they do pretty good! All you need to make them awesome is ATV tires, or just cut the turfs. | |
| Subject: Re: Craftsman Lt4000 mild off-roader January 21st 2018, 5:07 pm | |
| And lock it! I was amazed on what a difference the locked diff did when I locked my Husqvarna LT130. They are pretty much a craftsman. I am also surprised on how good the spicers do despite all the hate they get. I was bottoming it out, spinning my tires in 5th gear in the mud, doing mini burnouts and rocking it back an forward and no damage what so ever. | |
| Subject: Re: Craftsman Lt4000 mild off-roader January 21st 2018, 11:57 pm | |
| No, it keeps friction down better than grease. Also, when you pulley swap it, unless you do an oil swap, it makes all kinds of weird noises its not supposed to. Grease also has a habit of getting packed into the corners and becoming ineffective. | |
Age : 25 Join date : 2016-07-10 Points : 8379 Posts : 5190 Location : Ontario Canada
| Subject: Re: Craftsman Lt4000 mild off-roader January 22nd 2018, 12:10 am | |
| That's the nice thing about some of the older ones like my 600s is they're already oil filled. Way better than grease. MST series transaxles are also oil filled i believe. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: Craftsman Lt4000 mild off-roader January 22nd 2018, 12:17 am | |
| Yeah, I imagine they're not as bad as they're made out to be. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: Craftsman Lt4000 mild off-roader January 22nd 2018, 11:18 am | |
| No, I have mud lites. I wanted to leave my diff open because we have some really tight trails here, so tight that in some spots both tires rub on the trees. Obviously, I need a good turn radius for that. | |
Age : 21 Join date : 2016-10-29 Points : 6601 Posts : 3628 Location : Lewisburg, KY
| Subject: Re: Craftsman Lt4000 mild off-roader January 23rd 2018, 5:40 pm | |
| Spicer gearboxes are pretty good. Spicer transaxles are ok, but you gotta be kinda gentle with em, from what I've seen.
The steering radius on Mutt didnt change much with the diff lock, but she's a heavy tractor. Don't know what itd be like on a lighter one. | |
