| ATLTF 2018 Build-Off Competition "NellyBelle" LT1000 [2018 Build-Off Entry] | |
Double W Cross Ranch Expert
 | Subject: Re: ATLTF 2018 Build-Off Competition "NellyBelle" LT1000 [2018 Build-Off Entry] Sun Mar 25, 2018 3:01 pm | |
| Okay. I think for sway bar I'm going to use a skid plate, because I need one anyway, haha. |
Age : 14 Join date : 2017-06-09 Posts : 1202 Forum Rep : 18 Location : Central Texas
 | Subject: Re: ATLTF 2018 Build-Off Competition "NellyBelle" LT1000 [2018 Build-Off Entry] Sun Mar 25, 2018 3:08 pm | |
| - @biggasmowers wrote:
- I think the sway bar is for keeping the axle from rotating forward and back under acceleration/braking and the track bar keeps the axle from having right and left movement. Not sure how the sway bar pivots but the way the track bar is mounted allows each side to go up and down .
Seems like it would just lock up the axle. I just don't understand, and I don't want to start on it until I do. |
Crazy_Carl Master
Age : 29 Join date : 2017-10-30 Posts : 861 Forum Rep : 35 Location : Rochester, New York
 | Subject: Re: ATLTF 2018 Build-Off Competition "NellyBelle" LT1000 [2018 Build-Off Entry] Sun Mar 25, 2018 3:31 pm | |
Buck Mault Apprentice
Join date : 2017-11-01 Posts : 105 Forum Rep : 2 Location : Foggy East Coast
 | Subject: Re: ATLTF 2018 Build-Off Competition "NellyBelle" LT1000 [2018 Build-Off Entry] Sun Mar 25, 2018 4:16 pm | |
| all a sway bar does is transfer pressure from one tire to the other and body roll.
Edit sorry didnt see the video, thats a good video too
Age : 19 Join date : 2016-07-10 Posts : 2905 Forum Rep : 94 Location : Glencoe, Ontario
 | Subject: Re: ATLTF 2018 Build-Off Competition "NellyBelle" LT1000 [2018 Build-Off Entry] Sun Mar 25, 2018 5:37 pm | |
| A track bar is neccessary for most solid axle setups to locate the axle. Without one your axle will be potentially moving side to side while driving. If done wrong it can limit movement, but if you make it as level as possible and fairly long it will work fine. Here's my track bar on the MTD  A sway bar and sway bar links are to prevent body roll when turning at high speeds, but as others have said you don't really need that most likely for your setup. |
Crazy_Carl Master
 | Subject: Re: ATLTF 2018 Build-Off Competition "NellyBelle" LT1000 [2018 Build-Off Entry] Sun Mar 25, 2018 7:08 pm | |
| THE GOD HAS SPOKEN!  |
MightyRaze Moderator
Age : 43 Join date : 2016-09-06 Posts : 3283 Forum Rep : 125 Location : Shawnee, OK
 | Subject: Re: ATLTF 2018 Build-Off Competition "NellyBelle" LT1000 [2018 Build-Off Entry] Sun Mar 25, 2018 7:34 pm | |
muckmudd Veteran
Age : 15 Join date : 2017-07-11 Posts : 510 Forum Rep : 18 Location : In the shop
 | Subject: Re: ATLTF 2018 Build-Off Competition "NellyBelle" LT1000 [2018 Build-Off Entry] Sun Mar 25, 2018 8:02 pm | |
| That ones pretty good mighty. |
 | Subject: Re: ATLTF 2018 Build-Off Competition "NellyBelle" LT1000 [2018 Build-Off Entry] Tue Apr 10, 2018 2:45 pm | |
| So this build is on hold for a while, but I think I can finish it before the build off is up. Mean time, I been thinking. I want this build to go really fast, and have full suspension, and be very reliable. The rear suspension is probably going to flex the transaxle and crack the case. So what if I used a gear box or something?  I could mount it upside down, and run a sprocket drive to a live rear axle. As those of you who have seen my rear suspension know, I could easily mount a pair of pillow block bearings to the rear suspension and have a life axle. This would eliminate the trans issue, and the belt alignment issue from trans movement. I could then run a high ratio from the engine to the gear box and then run a 1-1 or maybe a 1-2 from the gear box to the axle, speeding this tractor up and making it reliable at the same time, especially since the gear boxes have a low gear reduction. And I know I'd have a bad turn radius, but mud lites on a live axle ain't never getting stuck so it's worth it, haha! Only issue is acquiring the gear box. I'd like to do this locally, so any ideas on where to find one? |
RichieRichOverdrive Expert
Age : 15 Join date : 2016-10-29 Posts : 1468 Forum Rep : 45 Location : Lewisburg, KY
 | Subject: Re: ATLTF 2018 Build-Off Competition "NellyBelle" LT1000 [2018 Build-Off Entry] Tue Apr 10, 2018 2:54 pm | |
| So you're thinking of a swing arm setup? |
 | Subject: Re: ATLTF 2018 Build-Off Competition "NellyBelle" LT1000 [2018 Build-Off Entry] Tue Apr 10, 2018 2:56 pm | |
| I have a swing arm setup. I'm afraid of flexing the trans so instead I want to put a live axle on it. |
 | Subject: Re: ATLTF 2018 Build-Off Competition "NellyBelle" LT1000 [2018 Build-Off Entry] Tue Apr 10, 2018 3:10 pm | |
| I don't know if just using a gear box is a good idea because with that setup you'd only have fast and faster, sorta useless. Be better to use a Peerless 700 or similar transmission. But come on, wouldn't a transaxle setup be much cooler? I think if you did the forward mount for the transaxle attatched to one of the radius arms like I've mentioned, the transaxle would be solid enough. Also fab up a track bar setup so that the trans doesnt try and move side to side, because that could wreck something for sure. |
biggasmowers Expert
Age : 17 Join date : 2016-12-30 Posts : 1490 Forum Rep : 36 Location : Kansas
 | Subject: Re: ATLTF 2018 Build-Off Competition "NellyBelle" LT1000 [2018 Build-Off Entry] Tue Apr 10, 2018 4:15 pm | |
| Keep the trans, get a welder and make a custom tranny holder that holds the tranny and takes all of the flex away. |
Crazy_Carl Master
 | Subject: Re: ATLTF 2018 Build-Off Competition "NellyBelle" LT1000 [2018 Build-Off Entry] Tue Apr 10, 2018 5:00 pm | |
| I like the idea like AllisKidD21 said of using a peerless 700 driving a live axle on a swing arm.
I also like the idea of keeping the transaxle you have, getting rid of the rear suspension, run it until it breaks, and then build your live axle swing arm setup. |
SebastianAlbrecht Apprentice
Age : 16 Join date : 2018-02-27 Posts : 116 Forum Rep : 2 Location : Germany
 | Subject: Re: ATLTF 2018 Build-Off Competition "NellyBelle" LT1000 [2018 Build-Off Entry] Wed Apr 11, 2018 7:15 am | |
| Both Ideas are cool. But I think, it's better to use a gearbox (in some old Murrays are 5 speed Gearboxes with chain driven rear axles) because it's easier to build, and more solid, you do'nt need to mess you with the Problem of the Belt Adjustment on the rear while suspension, .... |
 | Subject: Re: ATLTF 2018 Build-Off Competition "NellyBelle" LT1000 [2018 Build-Off Entry] Wed Apr 11, 2018 5:32 pm | |
| - @AllisKidD21 wrote:
- I don't know if just using a gear box is a good idea because with that setup you'd only have fast and faster, sorta useless. Be better to use a Peerless 700 or similar transmission. But come on, wouldn't a transaxle setup be much cooler? I think if you did the forward mount for the transaxle attatched to one of the radius arms like I've mentioned, the transaxle would be solid enough. Also fab up a track bar setup so that the trans doesnt try and move side to side, because that could wreck something for sure.
Well keep in mind the build goal. As fast as I can make it, with a lot of ground clearance and low center of gravity and a comfy ride. A transaxle is very prone to breaking under those circumstances. As for the fast and faster, I have something up my sleeve for that.  (P.S. When I said gear box, I meant something like a Peerless 700 or the Foote clone of it. - @Crazy_Carl wrote:
- I like the idea like AllisKidD21 said of using a peerless 700 driving a live axle on a swing arm.
Yeah but I'd prefer NOT to break my 920, lol. - @SebastianAlbrecht wrote:
- Both Ideas are cool. But I think, it's better to use a gearbox (in some old Murrays are 5 speed Gearboxes with chain driven rear axles) because it's easier to build, and more solid, you do'nt need to mess you with the Problem of the Belt Adjustment on the rear while suspension, ....
Yeah that's what I had in mind. And limited belt slip, because the belt is small and up and out of the way. So as for what I have up my sleeve....  Alright, that's all I'm going to say on that.... |
 | Subject: Re: ATLTF 2018 Build-Off Competition "NellyBelle" LT1000 [2018 Build-Off Entry] Wed Apr 11, 2018 5:44 pm | |
| While that is a super neat idea, I don't know if a bicycle de-railer like that would hold up to the torque and speed. If you do decide to try and it remember that it might not work so well with reverse.
 | Subject: Re: ATLTF 2018 Build-Off Competition "NellyBelle" LT1000 [2018 Build-Off Entry] Wed Apr 11, 2018 5:47 pm | |
- While that is a super neat idea, I don't know it a bicycle de-railer like would hold up in that application. If you do decide to try and it remember that it might not work so well with reverse.
Yes I know reverse won't work in the current set up. Might be able to get it to tho. I think it will hold up fine, it's an idler sprocket that the chain sits on and when you push it to the side it pushes the chain to the side. Edit: This also is not my idea, RatherBeWelding has this setup on his ATV. |
CraftsmanQuad19 Expert
Age : 17 Join date : 2016-04-12 Posts : 1183 Forum Rep : 37 Location : Indiana
 | Subject: Re: ATLTF 2018 Build-Off Competition "NellyBelle" LT1000 [2018 Build-Off Entry] Wed Apr 11, 2018 7:30 pm | |
| I was actually just thinking of this setup the other day |
 | Subject: Re: ATLTF 2018 Build-Off Competition "NellyBelle" LT1000 [2018 Build-Off Entry] Thu Apr 12, 2018 12:09 am | |
| Bicycle chain isn't gonna hold up to that kinda torque, not for long at least. |
biggasmowers Expert
 | Subject: Re: ATLTF 2018 Build-Off Competition "NellyBelle" LT1000 [2018 Build-Off Entry] Thu Apr 12, 2018 9:25 am | |
| I've always wanted to put bike tire a on a mower and take it through some deep mud and see how it does. |
 | Subject: Re: ATLTF 2018 Build-Off Competition "NellyBelle" LT1000 [2018 Build-Off Entry] Thu Apr 12, 2018 12:08 pm | |
| - @RichieRichOverdrive wrote:
- Bicycle chain isn't gonna hold up to that kinda torque, not for long at least.
The chain ain't what worries me, it's the thin sprocket. About 1/8" thick. The derailer can easily be reinforced. - @biggasmowers wrote:
- I've always wanted to put bike tire a on a mower and take it through some deep mud and see how it does.
Yeah it would need some guards for the chain for sure. Don't plan to test it in a mud hole (don't have any in dry Texas lol) but if I did the chain might get clogged. |
 | Subject: Re: ATLTF 2018 Build-Off Competition "NellyBelle" LT1000 [2018 Build-Off Entry] Thu Apr 12, 2018 6:35 pm | |
| I thought about putting some bicycle tires on the front lol, that'd be cool. But that chain really won't hold up for long. Neither will the sprocket. |
 | Subject: Re: ATLTF 2018 Build-Off Competition "NellyBelle" LT1000 [2018 Build-Off Entry] Fri Apr 13, 2018 3:21 pm | |
| Is it possible to convert the chained reverse on the 5 speed 920 to geared reverse? Could I use any gears that will fit, or does it have to be a gear designed to be a reverse gear? And is is possible to slow the ratio down while I'm at it because last time I drove this thing reverse was like 6 mph at idle, and that's just a little crazy, especially since I am using a slightly smaller rear pulley so it will then be faster.... |
 | Subject: Re: ATLTF 2018 Build-Off Competition "NellyBelle" LT1000 [2018 Build-Off Entry] Fri Apr 13, 2018 5:12 pm | |
| I think to do that the main and countershafts in the trans would have to be swapped out for the ones with the geared reverse, like from an MST. I doubt that's all though, and I also doubt the shafts would interchange perfectly. |
 | Subject: Re: ATLTF 2018 Build-Off Competition "NellyBelle" LT1000 [2018 Build-Off Entry]  | |
