| Richie's Murray Widebody- "Orion" | |
+7biggasmowers MightyRaze ConfederaSears Warren Evans AllisKidD21 CraftsmanQuad19 RichieRichOverdrive 11 posters |
| Subject: Re: Richie's Murray Widebody- "Orion" January 6th 2018, 8:26 pm | |
| Well part of the red wagon ana logy(ffs doug cmon) was that it just rides like a rock. It just rattles and bangs and skips if the ground is anything but solid pavement. It seems to be a common thing with Murrays and other light rigs. Mutt, in both her stock and current form, ride well. A good bit of weight just seems to make things move very fluidly, none of the jerkiness this thing has. Not to say the tires don't contribute to that. | |
Age : 21 Join date : 2016-10-29 Points : 6598 Posts : 3626 Location : Lewisburg, KY
biggasmowers Veteran Member
Age : 23 Join date : 2016-12-30 Points : 4721 Posts : 1944 Location : Kansas
| Subject: Re: Richie's Murray Widebody- "Orion" January 7th 2018, 10:36 am | |
| I prefer heavy mowers so they don't roll so easily, my murrays will go over so quick because of the riders weight is all on the rear and no front weight. the craftsman i used to off road with never flipped . Of course it had a cast axle and opposed twin with the battery in front of the engine so it was balanced really well, almost even with me riding it . | |
| Subject: Re: Richie's Murray Widebody- "Orion" January 7th 2018, 3:26 pm | |
| I used to roll my craftsman so much because it had a pretty high center of gravity. Murrays actually are a lot lower to the ground, and have a lower center of gravity, but they're really lightweight. I guess it'd be interesting how it would actually pan out, I haven't taken put this one through any real tests yet. | |
| Subject: Re: Richie's Murray Widebody- "Orion" January 7th 2018, 6:04 pm | |
| My little Ford used to be super top heavy when we first put the engine in and got it driving. I'm thinkin' the 16hp opposed and super narrow track/short wheel base was the cause of that, hahaha. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: Richie's Murray Widebody- "Orion" January 12th 2018, 9:50 pm | |
| Took Orion out for a rip in the snow today. Once you get some momentum she goes nice. Tipped her once, was drifting and caught a pothole in the snow. Of course, she didn't start til i dragged her back to the shop haha. She needs a locked diff though, would be a lot more fun that way lol. Bright headlights sure are nice. | |
| Subject: Re: Richie's Murray Widebody- "Orion" January 13th 2018, 11:25 am | |
| If i get an 820 i will doc lock it , maybe some more aggressive mud tires so i dont get stuck so bad like the last time . Not sure if a murray is worth putting an 820in tho lol | |
| Subject: Re: Richie's Murray Widebody- "Orion" January 21st 2018, 11:56 pm | |
| Post-snow damage/performance report:
-Clutch works pretty well -Trans gets warm enough to melt snow off it no matter oil level. Not sure if a normal thing. -Rear side dash mounts broken off, will weld dash to fender pan as soon as I get the mig welder back -Brakes need adjusted -Did surprisingly good for having an unlocked diff -No weird noises
So...cool I guess. Wish somebody'd come get this thing before I trash it completely. | |
Age : 23 Join date : 2016-04-12 Points : 5746 Posts : 2619 Location : Indiana
| Subject: Re: Richie's Murray Widebody- "Orion" January 22nd 2018, 8:42 am | |
- Post-snow damage/performance report:
So...cool I guess. Wish somebody'd come get this thing before I trash it completely. Sounds like the typical stuff I ran into. My mst gets pretty warm too. Dash mounts, 3 of the 4 main ones on mine broken, Have mine held down with bigger bolts and washers. Brake adjusted?, probably wont do any good. LOL | |
| Subject: Re: Richie's Murray Widebody- "Orion" January 22nd 2018, 9:05 am | |
| Brakes work pretty well on this. Would stop better if she had a locked diff though lol. But I've had her stop me going 30mph downhill, after some minor vibrations haha. | |
| Subject: Re: Richie's Murray Widebody- "Orion" January 27th 2018, 10:10 pm | |
| Finally kicked myself enough to get back out to the shop. Actually ended up bolting the dash back down in the rear with two bolt holes that only go into the fender fan and not the frame that I didn't bother with before. They were actually meant for like 1/4" bolts but I stuck the 5/16" self tappers that were from the mounts that broke off, they fit right in nicely. Didn't bother welding it. Also I noticed that the charge wire had come unhooked and hooked that back up. Oddly enough she started with the electric start for once and I drove her up outta the shop into the store building so I could work on other stuff. Carb needs cleaned lol. | |
| Subject: Re: Richie's Murray Widebody- "Orion" January 27th 2018, 11:17 pm | |
| Well it was reasonably warm here today, which is why i overhauled the foote ,reassembled my mst 930, welded a longer tongue on a mower trailer, made my parts pile, and cleaned the garage a bit lol | |
Age : 20 Join date : 2017-06-09 Points : 5283 Posts : 2640 Location : Literally Nowhere, Texas
| Subject: Re: Richie's Murray Widebody- "Orion" February 19th 2018, 9:58 pm | |
| Remembered that since my new phone works right, I can use a speedometer on it. Somehow this thing started right up. Gotta clean the carb again though lol. Hit a max of 29, wasn't fully wound out though. For anyone wondering, this is the DigiHUD app. Works excellent, and is free. | |
| Subject: Re: Richie's Murray Widebody- "Orion" March 3rd 2018, 11:21 pm | |
| Water in the carb...gross. Cleaned it and it still runs like trash. Oh well. Made a zero f*cks hood latch. Zero f*cks as in I don't care enough about this thing to make it look nice. Turned the ags back the right way too, and added a return spring to the gas pedal. Hate this junk so much. I'm done with riding it. | |
| Subject: Re: Richie's Murray Widebody- "Orion" March 3rd 2018, 11:57 pm | |
| Yeah I am sick of murrays. I wish I would have done the suspension on the LT4000 and left the Murray alone. Oh well. I like the attitude ! Even good days in the shop end with you wanting to blow the whole dang machine up. | |
Age : 22 Join date : 2018-02-27 Points : 3637 Posts : 1299
| Subject: Re: Richie's Murray Widebody- "Orion" March 29th 2018, 1:52 pm | |
| The front Tires you have from a ATV, I also want to use for my Mower. Rear Tires i also want to use AG Tires, but with a bit more thread. My Peerless MST-206-502C came out of the same Murray Widebody your Orion is. | |
Crazy_Carl Veteran Member
