KAL the Extended Journey.
+13 TheBeal
BlakeGroce
17 posters
Author Message MightyRaze Admin istrator
Join date : 2016-09-06Posts : 10652 Subject: Re: KAL the Extended Journey. August 5th 2020, 8:41 am Mostly the flywheel. Being the all cast one vs the one with plastic fins. And strangely enough, the intake manifold. It is much larger than the other one as well.
Age : 49Join date : 2016-09-06Points : 15086Posts : 10652Location : Oklahoma Subject: Re: KAL the Extended Journey. August 5th 2020, 9:06 am Decided to go out and measure those intakes.
15hp 1.25" diameter. (unrelated note, I think that fuel filter is backwards and the wrong one for fuel pump
18hp 1.5" diameter.
Finished project.
Age : 49Join date : 2016-09-06Points : 15086Posts : 10652Location : Oklahoma Subject: Re: KAL the Extended Journey. August 5th 2020, 12:52 pm So I got a bathroom scale and measure them. The 15hp Craftsman is 94.6LBS with oil. The black 18HP was 95.8 with oil. I would have thought it was much more than that. I just struggle with the black engine. I can manhandle the red one? 1.2 lbs seems so much more. Who knows.
RichieRichOverdrive Mod erator
Age : 21Join date : 2016-10-29Points : 6622Posts : 3639Location : Lewisburg, KY Subject: Re: KAL the Extended Journey. August 5th 2020, 1:49 pm Oppys are weird about intake manifolds, they went through several iterations. They were split like onan ones up until the mid 80s, where they went to a solid cast iron one, then it seems somewhere in the mid 90s they went to a solid cast aluminium one. I've had all three, they're functionally identical. Actually I'm not sure if they ever went to cast aluminum manifolds on horizontal oppys. I've seen some of the late year horizontal oppys and don't recall them having aluminum intakes. They had split and solid cast iron ones for sure though, as i had both of those.
Age : 49Join date : 2016-09-06Points : 15086Posts : 10652Location : Oklahoma Subject: Re: KAL the Extended Journey. August 5th 2020, 2:34 pm Yeah, this is the original intake for the points oppy that was originally on Kal. It's a split, I ended up using it on the hotrod craftsman phase.
Then the cast iron one from the 85-86 murray engine. Original to this engine.
Not sure if Red is aluminum or not, I think it may be cast iron too.
Murraymountain Veteran Member
Join date : 2019-02-04Points : 4223Posts : 2167Location : North Carolina Subject: Re: KAL the Extended Journey. August 5th 2020, 4:22 pm Yeah Red has a cast iron one. The rally has an aluminum and it is much shinier. You would definitely know if it was aluminum.
Age : 49Join date : 2016-09-06Points : 15086Posts : 10652Location : Oklahoma MightyRaze Admin istrator
Age : 49Join date : 2016-09-06Points : 15086Posts : 10652Location : Oklahoma Subject: Re: KAL the Extended Journey. August 23rd 2020, 9:16 pm Something to chew on until the next update.
From the spot I saved it from!
Updated pond spot.
TheBeal Veteran Member
Age : 29Join date : 2013-06-06Points : 5515Posts : 1398Location : Central PA MightyRaze Admin istrator
Age : 49Join date : 2016-09-06Points : 15086Posts : 10652Location : Oklahoma Subject: Re: KAL the Extended Journey. September 7th 2020, 10:50 pm VIDEO Simple little ride. First part of the video, you can sear how well that 18HP runs. Very happy with the engine. Few things to work on post ride: - Tie-rod ends need tightened back up.. Need some locktite. - Bracing plate on the side dash came loose. - The transaxle appears to have started leaking. Need to figure where. May have to pull it. Not bad yet, but is there.
Age : 49Join date : 2016-09-06Points : 15086Posts : 10652Location : Oklahoma Subject: Re: KAL the Extended Journey. March 30th 2021, 12:49 am I’ve come to a hard decision after a few months. I think I am going to retire Kal after Haspin this year. I know it is a cool build and has served me well.
Join date : 2021-01-15Points : 2637Posts : 1294Location : Upstate New York CraftsmanQuad19 Veteran Member
Age : 23Join date : 2016-04-12Points : 5761Posts : 2623Location : Indiana Subject: Re: KAL the Extended Journey. March 31st 2021, 8:04 pm What caused that decision to be made? I thought it was the most capable off-roader you had, and seemed to do very well at haspin for its height
Age : 49Join date : 2016-09-06Points : 15086Posts : 10652Location : Oklahoma Subject: Re: KAL the Extended Journey. April 4th 2021, 2:36 am CraftsmanQuad19 wrote: What caused that decision to be made? I thought it was the most capable off-roader you had, and seemed to do very well at haspin for its height I have Red just as capable I think now. Lots can change between now and Haspin. Right now, With my back issues as of late, I been toying with a new build idea, but will need some parts to make it more budget friendly. I would rather scrap Kal over Red for parts. But like I said, lots can change between now and Haspin.
Age : 49Join date : 2016-09-06Points : 15086Posts : 10652Location : Oklahoma Subject: Re: KAL the Extended Journey. April 25th 2021, 1:19 am Good news... I have had enough parts fall in my lap for my next build that I think Kal will be spared. Never hurts to have another rig on standby!
Like 1
Join date : 2021-01-15Points : 2637Posts : 1294Location : Upstate New York BlakeGroce Member
Age : 21Join date : 2019-06-02Points : 2320Posts : 469Location : Richmond Ky MightyRaze Admin istrator
Age : 49Join date : 2016-09-06Points : 15086Posts : 10652Location : Oklahoma Subject: Re: KAL the Extended Journey. June 28th 2021, 11:34 am Kal did great at Haspin. I won’t be able to get a full evaluation until we get home later this week.
Age : 49Join date : 2016-09-06Points : 15086Posts : 10652Location : Oklahoma Subject: Re: KAL the Extended Journey. September 27th 2021, 4:20 pm Well guys, Kal has had a good run. 2 successful trips to Haspin and more. This will be the end of the line for a good rig. Don't worry, the tractor will be back under a new name in the future. Just not sure how soon, but you will like it.
VIDEO So long Kal, for now....
redlinemotorsportts Mod erator
Age : 27Join date : 2013-03-18Points : 7285Posts : 3131Location : raleigh nc Subject: Re: KAL the Extended Journey. December 25th 2021, 11:36 pm Skimmed over this and the build-off thread. Really like how this looks, all stretched out the front, looks tough. Even though its retired, I enjoyed watching the build
Like 1
Age : 49Join date : 2016-09-06Points : 15086Posts : 10652Location : Oklahoma Subject: Re: KAL the Extended Journey. December 26th 2021, 1:30 am Thanks man! It was a fun build, and lots learned from it. While I have robbed a few parts from it, I haven't scrapped it yet.
Oh, and glad to see ya in the forum again
@redlinemotorsportts
MN mudder Member
2022 Build-Off Finalist
Join date : 2021-09-30Points : 1184Posts : 216Location : southern mn redlinemotorsportts Mod erator
Age : 27Join date : 2013-03-18Points : 7285Posts : 3131Location : raleigh nc Subject: Re: KAL the Extended Journey. December 27th 2021, 11:17 am MN mudder wrote: not to thread jack but @redlinemotorsportts is the old mtd still kicking around? Yea I still have it but 4 states away. Hopefully I can update yall around summer with it. PM me or move over to my thread for any other questions
MN mudder likes this post
Like 1
